Results 26 to 50 of 52
What did you do to your bike today V1(?)
    Feb 2012
    Re: What did you do to your bike today V1(?)
    Just wasted
    Sent from my Pixel XL using Tapatalk
    Too many bikes to list
    Mosdt likely drunkd
    everything is done.
    bleeding the clutch now. i think im gonna try to get some seat time in this week to give everything a dress rehearsal for saturday.
    We should ride Clough when I'm back from Deals before my sticker expires. My 200 is ready to go slow and fall down a lot.
    yes...we should
    Lifer Tekime's Avatar
    Mar 2016
    Falmouth, ME
    Dreams of helicoil with the head in place were just dreams, so now this...
    05GSXR75005SV65090DR350
    hosed about 10lbs of mud off the 350.
    tomorrow, I'm gonna document my clicker clicks and put my other wheels back on. and do laundry like the domestic diva I am.
    Senior Member myzx6's Avatar
    Apr 2014
    Riviera beach fl
    Not mine but got a 99 gsxr 600 that I'm getting going for my step brother (he bought it brand new back in 99) gas tank and carbs are in worse shape then I've ever seen and I've seen some pretty funky rusted up shit before. 2 pilot jets broke upon removal, so they are getting a pb soak and easy outed tomorrow (because it's sooo easy) trying to decide whether to do a vinegar soak or rig up an electrolysis contraption to clean the tank. I'll be shocked if there's anything left of the tank when the rust is gone.
    I’m so mad at myself right now. I never checked all my suspension settings from when I got the stuff back from being tuned. I just swapped wheels and was getting myself sorted and found I’d been running around with everything set to full stiff. Sunday was a wasted opportunity at this point.
    I’m boiling. I do, and should've known better.
    Feb 2012
    I woke up 5 hours ago and I'm full stiff what's the problem
    Mosdt likely drunkd
    you need a handy. as do I, to calm down and come back to earth.
    I've never ridden a bike full stiff. Seems like it would cause problems.
    Priapism.
    Yesterday I finished putting this ol' brute back together. She runs and works as should now. Plan to bring 'er to bike week.
    What did you do to your bike today V1(?)-img_2703-jpg
    Then tore into this one:
    What did you do to your bike today V1(?)-img_2705-jpg
    What did you do to your bike today V1(?)-img_2706-jpg
    Fresh oil, filter and clean air-cleaner. Forks are off and ready for mid-season-as-budget-allows refresh. Springs, oil, seals and misc tools are inbound. Plan to dig into these next week, maybe week after. No idea what I'm doing with dual-chamber forks.. but I watched a yuutube.. so.. you know.. should be good to go.
    Feb 2012
    I thought bike week was exclusively for Harley dad's with New Balances?
    Mosdt likely drunkd
    you cant even post a picture right side up. you should rethink doing the forks yourself
    Dude, they are USD forks. C'mon.
    2016 BMW S1000XR
    Mar 2016
    Falmouth, ME
    If there's a purgatory I'm pretty sure it's just an endless line of stripped threads and shitty Chinese helicoil kits.
    Being the genius I am I of course didn't bother with a test run, just drilled into my cylinder head. By some stroke of luck I didn't ruin anything important (yet). I knew this cheap kit would be difficult so it was no surprise that I went through a dozen coils. The insert tool is too wide, so once you screw the new coil down it compresses and locks up.
    BUT, managed to get two coils done, a third almost done until the insert tool broke. Hopefully a little Dremel action and I can get it wrapped up and button her up by weekend.
    TWINS! xrocket21's Avatar
    Central Maine
    Got the RC51 inspected!!!!
    34,459 miles
    Feb 2012
    Boots for the VF1000R came in. Got a 3 day weekend so going to rebuild the carbs and then hate my life trying to reinstall them. Joy.
    Mosdt likely drunkd
    Bought some frame sliders and engine guards a couple years ago and finally installed them today.
    2022 Husqvarna fe501s
    What did you do to your bike today V1(?)-img_2721-jpg
    Bought some irons and changed my tires, first time I've done that. PR4s are really stiff, took quite a bit of effort. Also changed all brake pads and rebuilt the rear caliper cause one of the pistons was dragging.
  21. #46
    Lifer Imbeek's Avatar
    Sep 2012
    Southwick,MA
    Washed the klx after 235 miles yesterday, mostly dirt roads and trails...the whole time had very little duplication but I don't think I was ever more than about 35 miles from my house.
    Member Tokyo Drift's Avatar
    Mar 2014
    NW CT
    I started doing my own tire changes last month. Going from Dunlop Q3's to Pirelli slicks on my F4i was a cake-walk; mounting the Angel GT A-spec on the VFR was not.
    Yup. Race rubber is even easier.
    My katiem got an oil change, fresh air cleaner. Clutch fluid transfusion. And a blingie new brake lever.
    Mar 2016
    Falmouth, ME
    New chain and sprockets for the DR: DID 520NZ-110 chain, JT front sprocket and decided to try a Sunstar E-Nickel Works Z rear, I stumbled on a crazy Amazon deal and scored the Sunstar for $20. Think it was a mistake because the price went back up to $70 right after I bought it...
    14T/48T definitely geared for dirt a bit
  25. #50
    De-rusted the fuel system on the FZR, new fuel filters, tank is off and getting evaporusted currently.
    Cleaned the WR. Considering shortening up the gearing from 13/47 to 12/47 before the next Boxshop round.
    Looked at the KTM, still orange.
    Didn't look at the R6.
  1. New bike today....
    By MikeyZ in forum Welcome and Intro
    Last Post: 05-31-11, 12:53 AM
  2. Put The Bike Away Today....
    By BrianC in forum Bike Maintenance
    Last Post: 11-30-10, 02:56 PM
  3. Took the bike out today......
    By Rice-rocket1 in forum General Bike Related
    Last Post: 04-11-05, 06:37 PM
  4. Got hit today on the bike....
    By Daytona440 in forum General Bike Related
    Last Post: 08-11-04, 01:40 PM
  5. saw a bike today . .
    By Gangsta SV in forum Bike Maintenance
    Last Post: 04-29-03, 05:13 PM
