Results 1 to 21 of 21
bmc filter
    Posting Freak crowspeed07's Avatar
    Feb 2009
    south shore
    bmc filter
    i got a bmc filter and was told its the race version just wondering if there is a way to make sure of this?
    2007 Kawasaki zx6r
    Posting Freak boloson's Avatar
    Oct 2007
    Re: bmc filter
    Quote Originally Posted by crowspeed07 View Post
    Race filter should have a green line through it
    Feb 2009
    south shore
    Re: bmc filter
    this one looks ot be solid red. if its non race filter can i just install without the need for a power commander?
    2007 Kawasaki zx6r
    Re: bmc filter
    you "should" get a power commander for any after market filter. the race ones just filter less
    EX 105 : CCS Atlantic, Mid Atlantic, South East, Florida, and WERA
    Sponsors: Motul, Michelin/STS, K&N, Woodcraft
    Oct 2007
    Re: bmc filter
    Yup. Since the race flows more air then I would definitely get a pc
    Re: bmc filter
    Some BMCs flow worse than OEM...
    Quote Originally Posted by Kurlon
    I have heard that before but I think it's utter bs. I'm willing to be proven wrong but I have seen demonstrations of airflow between own and Bmc and the difference is staggering (on the demos I have seen).
    Re: bmc filter
    Flow is one thing but resonance can affect flow.
    South Eastern Mass
    Re: bmc filter
    i can tell by judging by the intake noise/throttle response of my 675 that the bmc race deff helped my bike
    2006 Red Triumph Daytona 675
    Quote Originally Posted by bergs
    Agreed, somewhat. Suffice to say that most of the time more airflow is going to result in faster intake velocity and more air density in the inlet tract. Ram air effect don't work if you put a wall in front of it.
    Yeah, you could run into backflow and turbulence issues but we are talking about motorcycles here, not alcohol burning dragsters. We aren't exactly moving great gobs of air comparatively speaking.
    Re: bmc filter
    Not necessarily because we still have to consider air box design and how the affects of the occuring resonance will change as intake volume and speed increases. Air box and intake design is where I'm going with this.
    Also, at 14,000 rpms, the motorcycle engine is still consuming a fair amount of air.....sure, not as much as an 8000 HP racing engine when measuring sheer volume consumed but still, considering the reduced size of everything, alterations to the intake tract would likely yield some kind of noticeable affect be it positive or otherwise.
    Dropping in a free-flowing filter doesn't automatically mean there will be more allowable comsumption. Air box and intake design play a major part in this as well because if their design limits the flow then essentially one is pissing in the wind by using a drop-in filter.
    What are you running in your racebike?
    Not that I doubt tour argument Bergs. Just interested to know what you are running in the f4i. The main point I'm trying to make is that pretty sure a bmc race MUST be flowing more air than a stock filter.
    May 2007
    Southern NH
    Re: bmc filter
    Are you racing? Or is this for the street?
    Muhammad Ali.
    Re: bmc filter
    Bergs nailed it, while the BMC filter material does 'pass' more air, in some airboxes the BMC setup results in more turbulent flow over the intakes which results in a drop in power vs the stock setup. Ducati 996s are the application I'm directly familiar with. BMC's 'shower cap' style filter that goes over the intake bellmouths instead of in the runners does poorly compared to OEM filters on the dyno.
    I've seen similar power reversions on ST3s, open the airbox intakes too much, and power starts dipping.
    Ducati velocity stacks end up .5 inches from the underside of the gas tank which is the real problem. The bmc filters cause turbulence in that scenario because they fit over the bellmouth rather than tuck into the corner of the air box like the stockers do. With a race fuel tank and airbox on a duc the bmc would be a far better choice for that bike. That's not a bmc design flaw, it's a ducati one.
    And any race 996 shouldn't be running an air filter anyway. Filters on ducati's are for pussies.
    Re: bmc filter
    Agreed, it all boils down to a filter change shouldn't be done without taking other things into consideration.
    Bingo.
    It's only a matter of time now before we have complete closed-loop powerplant-driveline management onboard all bikes. This means managing all a/f, cam and ignition timing,intake length and traction direct from the ecu. No need for any aftermarket products like power commander etc. Plug and play exhausts and filters and let the bike take care of it all.
    Of course, this will be rest of the world only stuff. By the next few years the US EPA will have all bikes mandated to have tamper proof seals on the exhaust system and airbox.
    Of
    Central VT
    Re: bmc filter
    Since it hasn't been mentioned yet and it is important. Doc sucks.
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
  1. K&N X-Treme Motocross air filter vs. Foam filter?
    By Ductard in forum General Bike Related
    Last Post: 07-14-15, 01:05 PM
  2. RC-51 BMC air filter
    By jwm2k3 in forum For Sale
    Last Post: 12-30-08, 10:03 AM
  3. oil filter
    Last Post: 12-12-08, 02:35 PM
  4. What's in YOUR oil filter??
    By legalspeed in forum General Bike Related
    Last Post: 08-09-02, 02:13 PM
