3
Thought this might be helpful to some of you.
While reading a post on a Ducati forum noting issues with using Panigale (1199) calipers with other master cylinders; I came upon the following general info. concerning MC vs. Caliper sizing. Enjoy!
When you design a hydraulic system it's important to have good feedback from the lever as to how much lever force to apply to achieve a desired braking rate. Having good feel, sensitivity and control is the major factor influencing braking quality.
The main factor in designing good braking modulation characteristics is the ratio of the total area of the caliper pistons to the area of the master cylinder.
The Panigale calipers have a total piston area of 5655 sq. mm and has a master cylinder area of 201 sq. mm. This gives a hydraulic ratio of 5655/201 = 28.1.
The RCS brake master cylinder has an area of 284 sq. mm. Used with the Panigale calipers you get an hydraulic ratio of 5655/284 = 19.9.
A general design rule-of-thumb for twin rotor brake systems is as follows:
30:1 - soft feel
27:1 - sweet spot for design
23:1 - firm feel
20:1 - wooden feel
http://forums.13x.com/attachment.php...3&d=1350328035
Thank you,
Justin Torres
Owner of
Adrenaline cycle
2595 GAR Highway
Swansea, MA 02777
Phone. 1-508-379-0100
Fax. 1-508-379-0113
Web. Adrenalinecycleinc.com
Adrenalinecycleinc.net
