Results 1 to 13 of 13
Carburated bike question
    Lifer mycirus's Avatar
    Aug 2003
    Whitinsville, MA
    So the fuel switch? Do you just keep in on all the time. Shut it off when in the garage. Whats the norm. My buddy bought that 600 and just not sure what to do. I say just leave it on. Is that gonna hurt anything?
    Bruce
    May 2005
    Bernardston, MA
    I'll turn it off when I think of it, but for the most part I just leave it on. If for some reason the bike sits for a week or two w/ the fuel on, I think it manages to overfill the carb bowls a bit and will start hard and a bit smoky that first time after its sat, but with a daily start, never had any issues personally.
    Lifer BostonSVkid's Avatar
    Dec 2005
    I have a carbed bike and I dont have a shut off valve and I never have had a problem.
    2006 Ducati Monster S2R800
    Jun 2005
    no manual switch doesn't necessarily mean no switch at all... not sure about the SV, but it's probably vacuum actuated automatic... pistons stop moving, stop creating vacuum, valve closes. Hit the starter, pistons move, creates vacuum, valve opens.
    FWIW, I always close the valve on the KTM... don't always remember to open it, but the bike reminds me... usually on the face of the first 3rd gear double. Yikes
    the Sv has an automatic vacuum shutoff
    on my XV920R I have a manual vacuum shutyoff on each side of the tank, I shut them both off every time I shut the engine off
    Re: Carburated bike question
    Bruce
    if you leave the valve(s) open, it's common for the bowls to be overfull and cause problems with the floats
    I always learned, TURN them OFF
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    If you have no shut off it probably has a fuel pump
    If you are storing it for more then a couple of weeks the smart thing to do is shut it off and run it till the bowls are dry. On my BMW I know if I shut it off 1/3 a mile from the house it will be sputtering when I pull in the driveway. Then no loss of time.
    Glen Beck is John the Baptist
    FI obviously has a fuel pump, and that's why they have a tip over sensor to shut the fuel pump off.
    this thread is about carbed bikes, they get their fuel by gravity, if there is no obvious shutoff, it only means that there is a vacuum operated shutoff
    Aug 2004
    Baltic,CT
    MY 97 yzf1000 is carburetted and has a fuel pump
    most carbed model, there are exceptions to everything
    Oct 2001
    Bedford, MA
    The SV has a fuel pump too doesn't it?
    yes, but there is also a vacuum petcock that turns gas on & off
    I think the fuel pump is more of an accelerator pump, it's vacuum powered, not mechanical or electric
    Lifer Rye's Avatar
    Nov 2002
    Behind Enemy Lines
    Shut it off!
    '95 ZX7/9
    '02 XR650R
    '78 KZ1000
  1. Bike storage question.
    By Rambunctous in forum General Bike Related
    Last Post: 11-26-14, 07:03 AM
  2. carburated triumph won't start
    By 7UPyours in forum General Bike Related
    Last Post: 04-27-13, 09:49 AM
  3. Help pls, Question about selling a bike?
    By Bloke in forum General Bike Related
    Last Post: 04-25-05, 08:37 AM
  4. Used bike buying question
    Last Post: 06-04-04, 09:35 AM
