OK, I have adjusted the chain a bunch of times but wasn't sure if I did it right. I have a 2001 CBR929 and I do the adjustment on the rear race stand to the measurement in the book. I measure the slack in the chain by how much I can take the slack out towards the swing arm. I hope I am making this clear, I am pushing the chain up to the swingarm while measuring the slack in the chain. Is this the correct way? Does the bike need to have weight on it? What are your thoughts?
Thanks,
Danny
Ahhh, Dukey Wookey hurt his wittle hand, I'm the king of this gang now!
2001CBR 929RR
Lightly customized
Sounds about right. Err on the side of looseness if anything. I run my racebike chain way loose. You should adjust the chain with a person on the bike to give about 1" TOTAL deflection (1/2 inch each way).
Derek
"Too bad ponies are assholes."
OXX
Degs, the measurement be taken from the tightest section, am I right in thinking that??
And if you can pull the chain away from the rear sprocket (straight back) more than about 1/3 the tooth then start thinking about new chain and sprockets.
My ride's
95 FZR 1000
19xx DOUBLE "D"
Hey Degs,
Where on the bike do you measure the chain? Do you have a person sit on the bike when it is on the race stand?
Danny
2001CBR 929RR
Lightly customized
No, have someone sit on the bike OFF the stand. measure the slack halfway between countershaft cenetr point and rear wheel centerpoint, on the bottom section of chain.
Derek
OXX
The proper place to take your measure is usually a few inches down the swingarm from the piviot area, behind your foot peg a bit.![]()
Dont make the chain too tight or you are just causing the chain to stretch and wear out your sprockets way too fast.
2018 Harley Road Glide
2000 Ducati 900ss
2018 Onewheel XR
