HP specs are commonly published in two flavors: Crank and Rear Wheel.
I'm assuming RW comes from the dyno, how is Crank tested?
Can you extrapolate one from the other?
Some manufacturers like to publish Crank HP, probably b/c it's higher...
Thanks,
-Jack
'02 Duc MS4
"Admit Nothing, Deny Everything, Make Counter-Accusations"
Can't say for certain, but I thought they got the crank HP when they 'bench test' 'em...
Mark?![]()
....very likely....of course, like everything else.. I could be talkin' out my ass![]()
BHP= Brake horse power
The power it takes to "brake" a flywheel "drum" of a certain size and weight at a certain speed, basically.
degs
"Too bad ponies are assholes."
OXX
...I rest my case....![]()
???Originally posted by T-595 Greg
like everything else.. I could be takin' it up my ass![]()
of course, like everything else.. I could be takin' it up my ass
Originally posted by Stoneman
So THAT'S how you test Crank HP....![]()
'02 Duc MS4
By the way thats MY post. I have no idea why I was logged in that way!![]()
** Beware of cool down laps, injury may result**
Your log in is case sensitive...Originally posted by GuntherRC51
Nope. Only the password is case sensitive.Originally posted by Stoneman
Your log in is case sensitive...![]()
-Josh || Forum Rules || Stop. Think. Post.
That's what I get for thinking....Originally posted by JC
Nope. Only the password is case sensitive.![]()
And in these days of legalities and all that other bullshit...to claim '125hp engine' you have to show the ENGINE's horsepower, not what gets to the wheel after it gets through the drivetrain to the ground.
Plus, 125 sounds much more bad ass than 105.![]()
See...Originally posted by Degsy
degs
You didn't need me!
I was busy workin' anyway....
So..what's the difference between an inertial dyno versus an eddy current dyno?![]()
Eddy current helps your dyno, unless of course it "helps" you into a keeper-hole.Originally posted by TLRMan
'02 Duc MS4
inertial dynoOriginally posted by TLRMan
See...
You didn't need me!
a system that measures work (Torque/Horsepower) based on the acceleration of an object of a known mass.
and eddy current dyno has something to do with measuring braking power?
haha search engine, how wonderful.![]()
"fuckit!"
You guys are too funny sometimes.Originally posted by ShredHed
