Results 1 to 8 of 8
Best way to drill plastic?
    the phear hohum's Avatar
    Jul 2002
    Everett, MA
    OK, so I just got my frame/tail/bar-end sliders in the mail today, and now I am faced with figurin out the best way to drill a 2" hole in each of my side plastics... I figure I will lay out some masking tape on the front surface and just use one of those circular/saw drill bits. Is this gonna make a wreck out of my plastics?
    Cheers,
    Chris
    PS - the skyking sliders seem to be pretty nicely done...
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    steady hand and a dremel.
    Brent LRRS #772
    2006 KTM 560 SMR
    High maintenance priss
    Central MA
    I have used regular hole saws to cut old plastic fairings. You have to be real careful not to let the bit tear, twist or crack the plastic as it nears the end of the cut though.
    Dremel is a great tool to use to clean up the hole or make it larger.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    ...and go very slow
    Jul 2002
    Everett, MA
    Cool cool... Hopefully I can give it a shot tonight, and I don't end up with torn up plastics! I think I'll go the hole saw smaller than needed, dremel to size route.
    Cheers,
    Chris
    Mar 2002
    Amherst, NH
    Originally posted by bigred875
    ...and go very slow
    you just dont have the right bits.
    Brent LRRS #772
    2006 KTM 560 SMR
    Waterbury, VT
    Masking tape is a great idea. Make sure it's warm (room temp) so the plastic is flexible. Also lightly center punch the hole before drilling, and if you are using a hole saw predrill the center. If you don't given that it isn't a flat surface if the hole saw drill slips while drilling through it gets ugly fast.
    SSearchVT
    GRONSEL'D!!! gixxer6's Avatar
    Jan 2003
    Pissed that I can't race...
    hole saw
    Use a hole saw, period. We do it all the time for the race bikes
    Heath Smith
    LRRS/CCS #337
    Low Down Racing
    www.racetireservice.com
    www.motorbikesplus.com
    Power by Dr. Hillsgrove
    Traction by Franimal Racing Syndicate
    05' KTM 525SMR,
    01' YZ426F
    05' Reiju RS1
    Says Vale to Colin at the end of the 2002 8 Hours of Suzuka: "Ok Colin, you better go out there and win. Because it is the ONLY way we will NEVER have to come here again!"
  1. Safety wiring, need drill bits?
    By Honclfibr in forum Pit Area
    Last Post: 09-01-06, 06:03 AM
  2. drill my windscreen
    Last Post: 08-20-04, 12:46 PM
  3. why is it ?? the bolt broke ,then the drill
    Last Post: 02-05-04, 04:55 PM
