Results 1 to 17 of 17
Dumb rider rant...
    Oct 2001
    Bedford, MA
    Red face Dumb rider rant...
    Stupid VFR riders...
    The bike has very, very lean stock fuel injection causing some misbehavior under certain riding conditions.
    For some reason the logic in trying to figure this out is:
    a) (Optional) Ask other riders why the bike is like this. Recieve answer that the bike runs lean and a power commander will fix it
    b) Complain thatt $270 for a Power Commander is a rip off
    c) Spend $1000 for a pair staintune slip ons which lean the bike out even more
    d) Complain that the bike is still acting weird
    e) Spend $20 (?) on a K&N Air filter that is supposed to flow more air.
    f) Complain that the bike is still acting weird
    g) Spend $30 for a pair of O2 eliminators despite Dynojet saying they are for use with the PCIII.
    h) Complain that the bike is still acting weird
    i) Finally buy a power commander. Don't read the instructions. Don't select the correct map. Don't set the throttle position sensor.
    j) Take the PCIII out and say it didn't work and it's a bad product.
    k) Convince self that bike is running great..
    l) Wait 3 months and then complain some more that the bike is still not running great.
    Thanks for listening. There is no need for you to ever read a VFR forum now, I have just told you what 99.999% of the discussion is about.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    Dumb rider rant...
    Dec 2003
    Ma
    Dumb rider rant...
    Why didn't you just take the guy's advice and buy a powercommander to start with? Sometime's you just don't think stuff through Ben.....
    Oct 2001
    Bedford, MA
    Dumb rider rant...
    Definitely not me.. I don't have pipes and I've never tampered with the air filter.
    People are trying a lot of hokey stuff, plugging lines, altering the airbox etc..
    I've hopefully got my Corbin seat sold for at least what I paid for it. (Bought it used) That was definitely a mistake!
    The VFR *mailing* list is older and discusses the following:
    - Which oil to use
    - Regulator/Rectifier failures
    - Riders of other motorcycles are squids
    - Track riding is for fools
    - VTEC and any other engine advancements suck, even if Honda's next VTEC bike has a huge gain in horsepower
    - When is honda going to race the obviously superior V-4 again?
    - If you can't maintain it with a can opener, a twig, and duct tape, it obviously sucks
    Petrol sniffer MC's Avatar
    Lebanon, NH
    Dumb rider rant...
    Another satisfied VFRDiscussion member.
    '01 VFR 800
    May 2003
    Lakes Region, NH
    Dumb rider rant...
    hahahahaha - sounds like something that I would do....
    Bras cause cancer.
    Dumb rider rant...
    Ben,you could always go back to the SV board and snip the ignition retard wire and do a snorkleectomy and run Rotella
    the secret is Rotella, it is a known fact that it will cure all motorcycle ills
    May 2003
    Lakes Region, NH
    Dumb rider rant...
    wow - in your infinite wisdom you have managed to lose me again.....
    Bras cause cancer.
    Atlanta, GA
    Dumb rider rant...
    I'm lovin the Rotella, just did the synthetic Rotella this last change.
    Never understood why it's taboo to talk oil on SVRider.com when there are so many threads on installing undertails, or how to do a wheelie.
    Andrew
    03 Suzuki SV650
    granite state
    Dumb rider rant...
    i havn't gone on vfr discussion in a long time. very lame.
    ben i went with pipes as my first mod well second i removed the rear fender/snow shovel first. i'm a vain bitch. i love the looks and sound of my carbon remus pipes. i plan in the spring to get the power commander III. maybe you could show me the install process? you seem well versed in the subject on the pc III. -mike
    ultrabuddy twrayinma's Avatar
    Apr 2002
    albukoikee
    Dumb rider rant...
    because pretty much every oil thread turned into a flame war....
    now where'd i stash that screed on synthetic oil...
    Apr 2002
    albukoikee
    here it is!
    Beware of synthetic oil, it can do terrible things to you and your
    beloved motorcycle. It will not only leak out of your engine faster
    than you can put it in, but it will also cause your oil filter to
    clog and implode, dumping debris and dirt into your lubrication
    system. It also will make every part of your bike permanently
    slippery because of its linear molecular chain dispersion action.
    Then it will leak onto your kickstand causing it to retract
    automatically, dropping your bike on the ground! But that's not all...
    Synthetic oil will round off your gears and spin your bearings. It
    will also splatter onto your seat causing your girlfriend to fall off
    in the apex of a turn and she'll never ride with you again. Synthetic
    oil coats your sight window and your timing window with a whitish
    pro-emulsification additive that is both non-removable and highly
    corrosive. Synthetic oil will completely leak onto the ground overnight
    and your dog will drink it and die.
    Synthetic oil will wear out your tires and make your battery leak. It
    will give you the desperate need to urinate after you put your full
    leathers on and then jam your zippers shut. It will contaminate your
    gasoline causing your bike to stall on railroad tracks and accelerate
    uncontrollably near police cars. It will make it rain during rallies
    and on weekends. It will lubricate your timing belts causing them to
    jump teeth and break your valves to bits. Synthetic oil chemically
    weakens desmodromic valves and causes the clearances to change every
    six miles. Then it melts the black soles of your riding boots right
    before you walk across your new carpeting.
    While riding past groups of attractive women it will cause both of
    your handlebar grips to slip off at the same time so you smash your
    windscreen with the bridge of your nose. It also causes your swingarm
    to crack, your studs to break, and your rotors to warp, and then it
    voids your warranty by changing your odometer reading to 55,555. It
    also dries out your wetclutch and wets your dryclutch. It makes your
    clutch slave cylinder seal fail in the heaviest traffic on the hottest
    day of the year while putting an angry wasp in your helmet for good
    measure.
    Synthetic oil hides your 13mm socket and puts superglue on your
    earplugs. Synthetic oil will scratch your faceshield and make your
    gloves shrink two sizes night before trackday. Synthetic oil stole
    your neutral and sold it to the Chinese for $1.25. Synthetic oil
    will make you grow a tail. Synthetic oil will write long crazy
    e-mails to your Internet friends and then sign your name at the
    bottom!
    granite state
    Dumb rider rant...
    KB KB's Avatar
    Manchester NH
    Dumb rider rant...
    You should buy a Superhawk and get it over with.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    '04' Ducati S4R Wayne-o's Avatar
    May 2002
    Townsend, Ma.
    Dumb rider rant...
    The peeps on the VFR Discussion Forum are a pretty lame lot of people.
    May 2002
    Townsend, Ma.
    Dumb rider rant...
    Here's how they struck me when I had the VFR..............
    granite state
    Dumb rider rant...
    wayne you know you miss that vfr
  1. Yet another LBS rant
    Last Post: 05-01-06, 02:43 PM
  2. serious rant
    By OreoGaborio in forum Off-Topic
    Last Post: 05-14-05, 01:50 AM
  3. GBM Rant
    By Sideshow in forum General Bike Related
    Last Post: 03-24-05, 02:01 PM
  4. RANT!!
    By Cam22 in forum Off-Topic
    Last Post: 01-15-04, 06:29 PM
