Tried getting my flywheel off today and unfortunately had some setbacks:
1. first puller i tried cracked in half
2. second puller i tried nothing happened. banged on it TONS of times with my mini sledge, nothing.
3. went to autozone and got their puller as i read some have had luck with it. now where the problems began.
hooked it up and put my impact on her. SNAP. one of the bolts snapped about 1/8" above the flywheel face. spent a few mins trying to get vice grips on it but couldn't. got my bits and extractors out. drilled thru the bolt as the extractors couldn't get a bite. then i took the extractor and it was able to grab with a hole thru the bolt. it slowly started coming out then SNAP. the extractor grabbed the flywheel instead of the bolt and snapped off a little under flush than the flywheel face.
tried drilling again but the extractor is hardened steel. bit wouldn't even make a dent. wtf do I do now?!?
do they make massive 'jaw' type flywheel pullers? I was going to ask landrics what they thought or possibly harry's up in northboro what it would be to get the flywheel off, as i could take it from there...
thoughts?
