Results 1 to 6 of 6
Not the fuel pump
    Winter sucks Nate Dawg's Avatar
    Providence
    Not the fuel pump
    Ok, so the pump is working. The fuel pump relay, TO switch, kill switch, and side stand relay are working. The speedo is showing the bike is in Neutral. And still no sign of life to the fuel pump. The CHEC light is on when the ignition is turned ON. The rev needle goes up and down, but no sign of pump priming or the STVA doing anything.
    Any suggestions? I've done a ton of research online. Seems there have been more than a few people with similar issues.
    08 Ape RSV1000R
    09 Ram 1500 Black Big Horn
    10 Mini Cooper S sleeper (hers)
    Posting Freak tonup's Avatar
    Feb 2008
    Alton nh
    Re: Not the fuel pump
    CARBURRETOR
    Banned Euro trash-hole BCT748's Avatar
    Apr 2008
    Salem NH
    Do you have a wiring diagram? You could try jumping power down the line until nothing happens, at least then you would know it was between A and B.
    Unofficial self proclaimed official NESR plumber.
    "Ah shit son, datz be a Ducati!"-Random kid in Methuen.
    Providence
    I'm pretty sure the wiring diagram is in the service manual. Even with the manual I'm not sure if I know how to bypass things.
    This bike is going to be track bike only. So there isn't much concern for keeping all the wires if I don't have to.
    08 Ape RSV1000R
    Apr 2008
    Salem NH
    Follow the wires back from the pump. Every place you see a way to unplug them do it and apply power back towards the pump. Just make sure you are using the correct amount of power, you don't want to cause more problems than you already have. If you are nervous about that than you could always ohm it out and see if there are any dead spots.
    Providence
    This is the first GSXR I've owned.
    Man there are a ton of other owners on the gsxr and gixxer forum with very similar problems. I must say I'm pretty shocked!!
    08 Ape RSV1000R
  1. 04 cbr 600 f4i fuel pump not priming
    By Bocephus5781 in forum General Bike Related
    Last Post: 04-07-16, 07:35 PM
  2. WTB: 03-05 R6 fuel pump and windscreen
    By sdog30 in forum Wanted
    Last Post: 09-05-12, 02:53 PM
  3. i need a fuel pump!!!
    Last Post: 06-05-11, 08:27 PM
  4. fuel pump???
    By Nate Dawg in forum General Bike Related
    Last Post: 08-10-08, 12:54 AM
  5. Fuel Pump Testing
    By ZX-12R in forum Bike Maintenance
    Last Post: 04-28-07, 05:22 PM
