Results 1 to 12 of 12
Need some FZ1 info
    Jan 2010
    cny
    Need some FZ1 info
    Hey all, looking for those who have a non-inverted forks FZ1 (or maybe even inverted). I need some dimensions off the front rim if you have a few minutes? Some high res pics would be great of each side too..
    Also, how does the speedometer get its erading on these bikes, i was looking at an '02 micro fiche and it doesn't show a speedo gear on the front wheel, is it electrical? If so do any FZ1s have mechanical speedos?
    1. height and width of the rim.
    2. width between the inside of each rotor.
    3. Rotor diameter
    4. bolt pattern for rotors
    5. bolt pattern diameter
    and if you happen to have the wheel off:
    6. axle size
    7. OD of the bearings or ID of the hub where the bearings go.
    thanks!
    Re: Need some FZ1 info
    You want USD forks or not?
    2001 - 2005 have conventional forks
    2006 - present have USD forks
    Speedo is read off the transmission output shaft. All FZ1's have electrical tach and speedo.
    The other stuff requires a rim present and whether or not your application requires USD forks or not.
    Jan 2010
    cny
    ah okay so the speedo is electrical good to know.
    also i'd be dealing with convensional forks, but didn't know of the USD wheel (if different) would work better for my potential application.
    High maintenance priss
    Central MA
    I have a '07 R1 front rim (no tire mounted) if you want to borrow it for measurements. Its the same rim used in the GenII FZ1. Also have the R1 axle - looks a bit different than the FZ1 but diameter & length will be the same. Let me know and I'll bring them into work.
    Pretty sure GenII FZ1 rotors were 320mm. I think that the R1 radial forks required caliper spacers if using the FZ1 rotors.
    Jan 2010
    cny
    yea i'd love to just take a look at one to see if what i'm thinking is even possible...
    as long as its the same bolt pattern it might work..
    Lifer Wishbone's Avatar
    Jul 2006
    1. 17"x about 4 should find that in a fiche
    2. 128
    3. 300 but tough to say exact with the wheel on
    4. 6 bolt
    5. 150 center to center
    I can get more/better measurements this weekend if you'd like.
    Jan 2010
    cny
    Quote Originally Posted by Wishbone View Post
    2. 128
    4. 6 bolt
    thats good for now, i'll let ya know, i appreciate you taking the time. i bet the rotor is a 298mm, which is a standard (at least yamaha) size eh?
    i looked in a fiche for a size but no luck..
    also what yr is your fz1?
    Central MA
    Those specs Wishbone gave are from a GenI. And yeah, you're right that 298mm is the exact brake rotor size.
    Jul 2006
    2002
    That's funny because 298 seemed wrong LOL
    Apr 2006
    Beverly, MA
    I should have my Gen 2 FZ1 next week (08). You're welcome to measure anything you need to on it.
    Central MA
    Quote Originally Posted by schleppy View Post
    Can i measure top speed? Thanks!
    Apr 2006
    Beverly, MA
    I think it's in the 150 range. There you go!
  1. maybe just info?
    By loridin64 in forum For Sale
    Last Post: 03-23-08, 07:17 PM
  2. D2 info
    By SVRACER01 in forum Rides & Events
    Last Post: 11-02-07, 06:06 PM
  3. Toy run info (one of them)
    By PinHead in forum Rides & Events
    Last Post: 10-12-02, 01:35 PM
  4. Looking For Info...
    Last Post: 07-15-02, 08:13 AM
