Results 1 to 6 of 6
High Test finally worth it ?
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    I am surprised that the spread from regular to high test is still at 20 cents.
    Out of 3 dollars that's only 7 1/2 percent up charge.
    I would bet if there is a knock sensor retarding the timing on your thing then maybe you'll make out.
    Glen Beck is John the Baptist
    Posting Freak SWEET_Z's Avatar
    Jul 2002
    Smallbany, NY
    Lets hope it stays that way. I have to put 93 in my truck or it pings (supercharged). Costs me an extra 3 bucks or so per fill up from 87.
    I think the high test is made from the same base oil, it is just refined a little more. So the base oil cost is the same as 87. It just costs a little more to refine which is more of a fixed cost. I've been told the gas stations make the most profit on high octane.
    Jul 2002
    Waltham
    I have to use high test in my car as well but the difference in cost is usually $3.8 per tank if you use the $0.20 difference between low and high. I have been seeing a couple stations with $0.30 difference lately too.
    Aug 2004
    Baltic,CT
    Gixer takes it
    DRZ pings when stuck in a wallow and gets hot so
    it gets it too
    Oct 2001
    Bedford, MA
    If you need it use it otherwise it's still a waste to use it.
    I can't see why you would ever not run 93 in the Gixxer if it says it requires 93, it's a bike, it's not like it takes 30 gallons to fill the tank, you're talking about somewhere around $1 difference to fill the tank with 87 versus 93.
    IWOK Prez. bigred875's Avatar
    Manvile, RI
    manual says 87 for the Z i used to put 93 in...just because...have since switched and it's been fin...
  1. Test range for camera test?
    Last Post: 10-27-11, 02:14 PM
  2. High test and the single hose (ing)
    Last Post: 06-09-05, 01:03 PM
  3. Finally a new bike worth cosidering
    Last Post: 12-27-04, 01:56 PM
