Results 1 to 18 of 18
Randy O SV650
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Randy O SV650
    Randy you are obviously the expert on sv 650 longevity
    I am thinking of getting this as a commuter bike.
    Question:
    What chain life have you been experiencing ? When I think of utility I think of shaft drive but is that true any longer ?
    What sort of tire life ? My liter bikes cost 5 cents a mile in tires!!
    What kind of gas mileage ?
    I don't want my Gixer as a good commuter bike because tires, riding position, lack of carrying capacity aways trying to spin the tire etc.
    Glen Beck is John the Baptist
    Dr Q : Last resort Medic Qfactor's Avatar
    Homeless, MA
    Randy O SV650
    with my SV
    I have been experiencing:
    ~45-50mpg
    ~8,000mi per tires (80% commute,10% 2-up, 10% spirited)
    ~18,000mi per chain
    Q
    Randy O SV650
    Rich
    I have a scottoiler, and get about 35k from a set of sprockets & chain, front sprocket wears first
    I run 16/44 sprockets intead of stock 15/44-45
    Azaro ST tires I get about 10k-13k from the rear and 10k-17k from the front Avons VBD design requires high pressures for best longevity and performance , 42r 36f
    my SV is piped & jetted so my fuel economy suffers, stock with tall gearing you should get 50-60 unless your listening to the SV crying "feed me feed me, I love gazoline"
    I get 38-42 with my jetting
    Oct 2001
    Bedford, MA
    Randy O SV650
    Everyone will laugh at me for this but if you've got the $$ why not get a Buell or something like that for commuting.
    Belt drive
    No valve adjustments
    Better fuel economy then just about every japanese bike except a 250
    They may not make competitive power but they apparently are very good at making power on a minimum amount of gas.
    Just going to cost more then a SV no matter what.
    Aug 2004
    Baltic,CT
    Randy O SV650
    Randy
    Interesting about mileage though
    My last 3 literbikes when i rejetted them usually raising the needle a notch usually mileage improved into the low to mid 40's
    Last 300 mile day on the Gixer it did 44 mpg with zero modifications
    Are you pushing a windsheild or fairing at speed.
    My commute would be about 12 miles mild country and then town driving mostly under 60 mph
    Randy O SV650
    No, he's pushing Randy at speed. No offense Randy, but you are a bear of a man.
    degs
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    Randy O SV650
    Chris (madmax) over at ODFU rode his SV accross the country last summer ... he could probably give you some good insight
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    my buddy mark got a buell
    Belt drive
    & he loves it ...he's a wheelie popper all the time. he does eat belts !!!!! i think the belt is weak
    but i will say i would love 1
    www.bostonmoto.com
    Forum Rules
    Randy O SV650
    Randy
    like degs said, I'm a barn door, I do catch a lot of wind when I ride my worse milage is steady high speeds on the highway, prolly only get 35 or less, on a leisurly cruise, even 2up, I can get 45 or maybe a little better
    my XV 920R is a great all around bike, I get 55 mpg consistently, it has an enclosed non o-ring 630 chain, almost 50k on the original chain, I've never had to touch it in the 20k I've owned it
    makes about the same hp as the SV, somewhat better suspension than the SV too and least it's got some damping & rebound adjustment
    Lifer Currently's Avatar
    Ooltewah, TN
    Randy O SV650
    I use my SV for commuting 70 miles a day, 35 each way.
    It is the perfect commuting bike. The seat kind of sucks
    for anything over a hundred miles but that can be changed.
    I got a Corbin seat but I don't like it. I will try rebuilding the
    stock seat with dense automotive foam and if that works,
    I will be selling the Corbin. (fits '04 -06)
    The thing that surprised me the most about the SV is that
    it is a bike that is modified a lot and there is an unbeliveable
    amount of stock parts available for pennies on the dollar.
    The only time I don't ride is when they forcast heavy rain.
    I don't like the misting that reduces visibility on the highways.
    Atlanta, GA
    Re: Randy O SV650
    A lot of SV'ers get over 15k on the chain given the bike's modest power and of course how well it is cared for.
    The SV has been very good to me in terms of tires, Put about 8k on stock D220s and they had ~30% tread when removed, put about 6k on a set of pilot powers including 3 track days, and the tires are very much still usable, if not a bit flat from the highway.
    My MPG has fluctuated between 35 and close to 50, I think it's been a function of wind, tire type/pressure and how much throttle.
    You can get a decent tank bag and a set of soft bags for around/under $200 and have plenty of storage, some guys do Givi bags which are $$$, yet another option is a Givi top trunk screwed into a spare passenger seat, a bit goofy looking but 100% of storage (sans passenger) for like 1/2 the cost.
    If it was me and I was looking for commuter I'd look for basically any SV that has been well cared for, any year works. And you may be looking for a windscreen as well, unless you don't mind being blown around a bit.
    Also I'd try riding someone's SV and see what you think of it if you haven't already. The suspension is very soft and you may want to plan at least throwing in some heavier oil and cranking the stock shock up, if not one of the many upgrade paths out there, but that is $$$.
    Go to svrider.com, and you will get a lot of FB from folks that do a good 10-20k a year commuting on their SVs.
    Andrew
    03 Suzuki SV650
    Lifer Ken C's Avatar
    Sep 2001
    Western MA
    Randy O SV650
    Rich, How about commuting on the DRz? Isn't yours street-legal?
    I've been doing it all week. 50 mpg with pipe and jetting. (Considering going back to stock). It's fun!
    Aug 2004
    Baltic,CT
    Randy O SV650
    Its been under advisement
    Currently zero carrying capacity on the DRZ
    Could be possibility with a back porch installed. I have been using my old R80 when weather is OK but its really an artifact and if I am considering being a bike commuter then
    the yzf is going soon
    the R80 eithr goes now or after brother visits in July
    On my commuter list is "Used"
    sv 650 not s
    KLR 650
    even a burgman ... no splashing
    Atlanta, GA
    Randy O SV650
    How big is your commute and what speeds are you talking?
    I had more fun riding my brother's 49cc Zuma to work which was 5 miles of in-town, large iced coffee on the floorboards btwn my feet, and it was all good. Burgman may be an interesting contender, what about Silver Wing? They are kind of $$$ I think however.
    Andrew
    03 Suzuki SV650
    Aug 2004
    Baltic,CT
    Randy O SV650
    I know I will be unpopular but
    after closes analysis I never seem to think Honda
    The 2 wheeled way for work is country road to town riding. It is a total of like 12 miles each way. More fun and less likely to be a hood ornament.
    Reports of the 400 cc Burgman has 75 mpg and possible 70 mph cruise. The large luggage capacity and out of the splash and dirt factor are attractive on scooters going to work.
    If both were presented I would probably go for the 650 burgman.
    My 2 wheeled safety idea is always to be moving faster then traffic so I am passing and not being passed. That is why I would discount anything under a 250
    I don't know about the scooter.
    The old man joke
    "Did I ever tell you about the worst sex I ever had?"
    "It was wonderful"
    I have never found a motorcycle I didn't like so I think it would carry to scooters.
    And then I could join one of the outlaw scooter gangs
    Sep 2001
    Western MA
    Randy O SV650
    A co-worker has a 400cc Yamaha "Magesty" It looks pretty good and I could fit a week's worth of groceries under that seat.
    Atlanta, GA
    Randy O SV650
    I'd try the scooter then if the $ was reasonable. The biggest problem I have with going 5 days a week commuting on my bike (outside of rain) is storage. Need to haul computer bag with big laptop, and gym bag with change of clothes. It's too much for a single backpack. A milk crate on the back of a scooter would do the trick I think
    Andrew
    03 Suzuki SV650
    Aug 2004
    Baltic,CT
    Randy O SV650
    I was in Taiwan and its small scooter crazy
    Special parking and even traffic lanes for scooters only.
    I am believing that the bigger scooters were designed for commuting in europe including Large underseat storage.
    Room for bags laptops and rainsuit. Be easy enough to check out at a dealership
    Took my DRZ in the mysty morning now have damp feet.
    Love the ride but have mental block against it and trashing it in the woods
    The scooters are dry except during real rain. Wet roads and puddles I believe not a problem
  1. Randy O
    Last Post: 05-04-07, 12:55 PM
