I had had it with the mush that was the braking system on my race bike. It had a Nissin radial master off an 08 GSX-R1000 and the stock 2 piston calipers.
Even with a brand new set of carbon brake pads, the lever was still mush. Even after constant bleeding.
Since I have no intention on running SuperSport, as bike is disqualified due to engine work and the upper fork tubes from a 97 ZX6R, I picked up a few bits that have made my braking system 1000 times better.
I grabbed a 16x18 Brembo master (from eBay), which is stock from an 08 R1.
I also picked up a set of SV Racing Parts 4 piston caliper adapters for 4 pot Tokico calipers. And for twice the power, I picked up a set of 4 piston Tokico calipers from an 04 SV1000 off a member of the SVRider board.
It didn't take much bleeding and the brake lever is now solid. I can't wait to get the bike back up on the track. If anyone with an SV650 wants better braking and doesn't want to do the whole GSX-R front end swap thing, this is simple enough to do. I had it done inside 90 minutes, including safety wiring and bleeding.
