as stated i lost my only key to my sv... of course right before the classic. whats my best plan of attack? dealer needs me to pull the ignition on the chance of a key code being stamped. locksmith in my area that can make keys from locks will be atleast a week to have time. i was going to just jump the ignition but then i remembered ill probably need some gas and thetank is keyed as well. FACK![]()
Lrrs/ccs expert #221
Looks like you are going to have to jump the ignition and screwdriver the gas cap
then change your gas cap to screw type
take the ignition out. you dont want one on a race bike anyways. run the ignition wire to your kill switch.
unscrew the gas cap & put a vortex twist cap on.
done and done
EX 105 : CCS Atlantic, Mid Atlantic, South East, Florida, and WERA
Sponsors: Motul, Michelin/STS, K&N, Woodcraft
gino, nothing is easy on a 1834 Honda Hawk.
Keith is on an SV. he's got 3 hex bolts that are 5mm that screw the cap into the tank.
ahh, my bad.
i saw bike issues before the classic & made an assumption
thats my poorly written post to blame there jim... and my sv is a second gen scott but thanks
Did you try to call a different locksmith?
Bruce
2007 VFR800 25th Anniversary
2003 Honda RC51
What about getting a few guys to lift it up and bring it to the classic?
I don't know about an SV, so this post may be next to useless, but i do know of people who thought the same on certain Yamahas only to break the ignition bolts, pull it apart, and find nothing. Doesn't sound from your posts that you're about to tear things open without doing a little research, but just wanted to throw that out there in case you've got a sledgehammer in your hand already.
Have some local friends with SVs? see if their key opens your gas tank (I know a few hondas that will open using a bunch of different honda keys)
thats exactly what i'm afraid of
nope :-/ i have no friends
A good locksmith should easily be able to pop the gas tank. Most of them carry a lockpick set (at least the one that I knew did).
2015 KTM 1290 Super Adventure
2017 Honda CRF250L Rally
The local locksmith to me was able to make a key in his van in about 10 minutes after wiggling a blank in the ignition a couple times. One more tweak in the van and it worked on the gas cap as well. Call around, you'll end up paying for the service but someone will be able to help.
you must have some magicians in maine cause i just got off the phone with a really reputable smith and he said im most likely lookin at a 200 dolla tear down for him to make a key blind...and hes got like a week back up
if you are not racing whats the big deal about the classic? get a friends bike or take a car up?
