I'm looking for a dealer in the NH or MA area that has Pitbull rear "spooled and non spooled stands does anybody know of any?? Thanks!
Don't know of a dealer off hand but I just saw a post on sportbikes.net I think where someone had a front and rear stand for sale.... 100.00 each I think it was
99 R1 with BRR front among other things
01 WR426
Chip I was hoping to pick one up this weekend so I could raise the triple back to street form....40mm is tasty but I'm sure once the roads clear Ill have trouble with clearance. I'm thining 10mm is the sweet spot I'm at 40mm right now:o
Yeah 40 is a bit extreme.. I'm going to drop mine the 10mm but I really was waiting for my Scotts to come in first... where are you located? I've got a front and rear here in New Bedford.... I could bring em up to the track (Epping)with me May 1st if you want to do it that night I should have whatever tools you'll need there...
01 WR426
Thanks Chip If I dont get the rear end stand before then I will definetly hit you up! B-T-W how does that electronic shift treat you at the track?
[Edited on 4/27/02 by RevHappy]
It's sweet if I could only keep the front end down... I'm not sure what I'm going to run for gearing on wed. yet.. but the shifter makes the sweeet POP as you bang from one gear to the next a full throttle![]()
01 WR426
Chip do you use that elec. shifter all the time even just cruising? I heard that the 1st to 2nd shifts if they werent at high rpms where a bit rough? Is this true I've been kicking around the Idea of buying one for 3 years now..
Yes I pretty much leave it on all the time...the first to second shift is not a problem you just have to make sure you give it a good push to get it through neutral...
01 WR426
