Results 26 to 50 of 59
REMINDER - trailer bearings
    Lifer Punjistick's Avatar
    Norwell, MA
    Re: REMINDER - trailer bearings
    Not saying it's correct, but I'm seeing online that too much grease actually can cause more heat and is a waste. I get the waste part maybe but not sure about the heat. Seems like boat trailers back it full since they don't want water in there.
    Money must be really tight if they are worrying about wasting a little grease on their trailer bearings.
    Lifer Falko's Avatar
    MoonTown
    Pack'em. As the bearings get warm, the grease gets less viscous and doesn't stay in place well. You want enough to move around in there and keep things, well, greasy.
    Posting Freak Tas's Avatar
    Sep 2013
    Jaffrey NH
    I've been thinking about this same thing. I bought the bearing covers with the grease fitting and there seems to be a lot of space between the bearing cover and bearing to pack them full of grease.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Bearing buddies work by having a reserve of grease to keep pushing onto the front bearing, keeping it under positive pressure so water can't work in. That also means that over time it's constantly pushing grease past the seal and loosing some, hence the extra capacity. Note, bearing buddies also don't do a thing for rear bearings on most setups.
    Lifer Rosco61's Avatar
    Oct 2007
    Peabody Ma
    Just you tube servicing trailer bearings. There are step by step destructions on how to do this. It's fundamental mechanics.
    A few simple tools and a grease gun.
    Have fun.
    You mean inner bearings?
    Unless you have 4 seals per hub or sealed bearings, then grease being pushed through the first bearing should make it's way past to the second. And since there is only one exit present (bearing buddy is the other exit which is now blocked), why wouldn't it make it to the inner bearing?
    My grease gets pushed to the inner seal on my trailers with BB's... Meaning it makes it through both bearings.
    2016 BMW S1000XR
    I'll have to get bored enough to pull my hubs on my cheapie trailer, I seem to recall grease not making it to the inners worth a damn but I've also stopped caring about that thing so... been quite awhile since I laid eyes on it. My EZ-Lubes actually have grease hitting the inners first, then it pushes to the outers so you can see when you get the system full.
    I do have a lot of grease coming out of my inner seal, so it's getting to both.
    2016 BMW S1000XR
    Sep 2013
    Jaffrey NH
    Thanks for the additional insight.....will be greasing them this week.
    2004 SV650
    1979 GS 850GN
    2005 Tt-r125
    Lifer Pittenger5's Avatar
    Austin
    Anyone else hard right now?
    Zip Tie Alley #505
    MoonTown
    I have oil bath hubs on my big trailer, PIA....
    Lifer capitalcrew's Avatar
    Feb 2017
    Albany NY
    Run em till they lock up, then just back up a bit to get the wheel turning and drive home on the axle. No big deal.
    Raymond NH
    You don't need to fill all the gaps in the hub cavity with grease, just pack the bearings properly, set the pre-load properly, seal 'em up and you are good to go for years. You don't need bearing buddies on a non-boat trailer, they are only there for the sole purpose of preventing water intrusion and were never meant to be used as a means to lube the bearings.
    Norwell, MA
    REMINDER - trailer bearings-img_20170516_221151-jpgREMINDER - trailer bearings-img_20170516_221119-jpg
    Let's play spot the bad bearing...
    What are my options for a replacement hub? It's from a Harbor Freight 4x8 trailer, which I think is actually a Haul-Master? 4 lug, 12" wheel.
    Raymond NH
    Just replace the bearings, seal and races, don't need a new hub unless you can find one cheaper than bearings, seal and races.
    Feb 2017
    Albany NY
    Yeah man just drive out that outer race from the back side and drive the new one in and you're good to go.
    Raymond NH
    If you are ever in the Raymond NH area, I'd be happy to knock out those races and press new ones in, I have an arbor press and it's a <5 minute job.
    Edited to add: That offer extends to anyone on here, BTW.
    Alex, I got a spare HF trailer, nearly brand new if you end up in a pinch. Might be cheaper to just replace the trailer, lol.
    2016 BMW S1000XR
    Norwell, MA
    Thanks guys. O'Reilly Auto had replacement bearings and I rented a puller and driver set. Hopefully that's enough to get it back on the road. I sure am glad I'm doing this at home, in a garage with lots of light, and not on the side of the road next month!
    Puller and driver set? You mean a long screwdriver and the old races?
    2016 BMW S1000XR
    Raymond NH
    A puller probably won't help you much, there's not much of a lip on the back of the races to get a purchase on with a puller. The best tool, IMO, is a long cold chisel with the blade ground to a flat face. A short cold chisel will work, but will likely result in busted knuckles. The long one will let you really swing the hammer with gusto and pop those races out in 3 or 4 hits, alternating from side to side. I have a Stanley Fat Max 1" chisel that's 12" long and works perfectly for this endeavor. I bought it at Lowes. Can't seem to paste a link here, but search lowes for "stanley fat max 1"" It's 9 bucks.
  23. #48
    Norwell, MA
    Yeah I don't know why I thought I could use a 3 jaw puller. I got the jaw to grab but had nothing to pull against. I ended up using a piece of flat rectangular aluminum bar stock and a hammer. It popped right out easily. Thanks for all the help. Trailer is back together and I plan to take it out on a shake-down run Saturday.
    Central VT
    A couple thoughts from this weekends trailer maintenance. This is all relative to the HF folding trailer but probably good to keep in mind. Be careful when using the grease gun if the tire is off the ground on the side that you're working as if the wheel rotates with the grease gun on the grease fitting it can shear the fitting in half. Also, if your tires are more than 5 years old check them for cracking. Also a good time to check all of the bulbs and keep a couple spares in your track tool box.
    Jake
    2006 ZX-10R
    1999 Kawasaki ZRX1100
  25. #50
    xxaarraa
    Guest
    This thread prompted me to grease my trailer bearings today, good karma to OP.
    I recently got this "lock n lube" grease gun attachment, and highly recommend it. Man it makes fitting and unfitting the gun/hose on the zerk so much easier.
    Amazon.com: LockNLube Grease Gun Coupler - Zerk Grease Coupler Fitting Tip - Easy Lock-on, Clip-off - Stays on - Grease goes in, not on the machine: Automotive
  1. For Sale - Other | Trailer hubs with bearings, 5 lug
    By Falko in forum For Sale
    Last Post: 10-02-17, 06:42 PM
  2. Trailer - Bearings and tires?
    By knarlydog in forum General Bike Related
    Last Post: 09-24-13, 12:50 PM
  3. Trailer Bearings?
    Last Post: 03-12-09, 01:36 PM
  4. wheel bearings on a trailer - need help
    By Crash Dummy Denno in forum Bike Maintenance
    Last Post: 05-20-08, 08:09 AM
