Page 4 of 4 FirstFirst 1234
Results 76 to 85 of 85
V-strom build
  1. #76
    Re: V-strom build
    Randy Strommer are have an intimate Peep show up at Cupsuptic/Rangely
    Poorly attended all the Canucks are some where else in Northern Quebec
    gonna hafta be a last minute decision for me, and not as fucking cold as last one I attended,
    As beet would say: "ta fuck?"
    leaf peeper ride, late season western Maine, adventure ride
    campout
    0 Not allowed!
  2. #77
    Lifer Stromper's Avatar
    Eastern Ct
    Re: V-strom build
    Pete is putting on the Vstrom fall camp and ride referred to as the Peep show in stromtroopers events
    You were there twice way back at Cupsuptic campground
    A few of the regulars have other commitments so not the normal about 25 attendees but maybe only about 10
    Now that your "BACK" wanted to let you know
    0 Not allowed!
    The calculus of hate
  3. #78
    Re: V-strom build
    SO what's the story with the 'Strom, Randy? Did you get it back?
    0 Not allowed!
  4. #79
    Re: V-strom build
    got word today, it's alive, intermittent fuel pump issues were combination of faulty fuel pump relay AND tip over sensor. brakes are a bit sticky, calipers will come off and cleaned.
    0 Not allowed!
  5. #80
    Eastern Ct
    Re: V-strom build
    Glad stuff is coming together for you
    0 Not allowed!
  6. #81
    Re: V-strom build
    dealer should deliver my Vee tomorrow, gonna buy the K-Pipe too, maybe ride that home
    0 Not allowed!
  7. #82
    Eastern Ct
    Re: V-strom build
    I bet it would be happy with a REAL break in*,, change the oil when you get it home,, use conventional
    * Modified Motoman
    0 Not allowed!
  8. #83
    Re: V-strom build
    * Modified Motoman
    I pulled em both into my office but took the k-pipe out for a short 2 mile ride. It was FUCKING COLD yesterday, high temp was maybe 28, zero wind protection on the k-pipe. I had work today, tomorrow supposed to get up to 45, I will probaby take both of em out. They both have fresh oil changes.
    The K-pipe actually starts quicker and stronger with the kick start, you dont even have the kicker halfway to the bottom of the stroke and it's running, even when it had a dead battery at the dealer, They put in a new battery, and a Battery Tender with a pigtail connected. no storage under seat, so it doesn't have quick release. It takes more cranking with the electric start. shift is n on top then 1-4 down, has a heel/toe shifter, single disk in front, drum in back
    0 Not allowed!
  9. #84
    Re: V-strom build
    You can get an alternate shift drum that'll make it a traditional 1N234 shift pattern if you want.
    0 Not allowed!
    771 Racing -=- FaceBook
    Backed by Heroic Racing Apparel / Warp9 Racing
    Mistake - 1992 WR250ZD / 2000 LS650P
  10. #85
    Re: V-strom build
    I have already posted that my next task in the V-Strom build will be an auxiliary battery box, at the same time, I will be working on the wiring, I have enlarged a wiring diagram to plan size sheet and tacked it to the wall next to a dry erase board, I will be able to sort everything out and build the loom right there
    V-strom build-img_2181-1-jpgV-strom build-img_2183-1-jpg
    0 Not allowed!
