Results 1 to 6 of 6
Winterizing question......
    Littering and........
    Jul 2004
    Vermont
    I am pulling apart Frankenbike to bring the plastics and the tank to be painted. Is it bad if I pull the tank off, and run the bike until the fuel lines are empty? Will some residual gas be left in the carbs that will cause me problems?
    Northampton, MA
    There will always be residual gas left in there. Best bet? Use the bowl drain screws.
    What he said. There should be a little drain screw on the BOTTOM of each carb. Then again, if you stabilized the gas (as talked about in the other thread), you shouldn't hafta bother with either...
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    Yes
    don't care about a little
    more concern that bike is hot for last shut down to drive off moisture and combustion moisture
    Glen Beck is John the Baptist
    Lifer Suf Daddy's Avatar
    Nov 2003
    Boston, Lincoln, other locations
    Highsider
    to bastardize your thread.......................
    Use some of that "jelley" in your bathroom to winterize your ride.
    You seem to think it has some usefulness for other applications :-)
    -Suf Daddy
    Suf Daddy.
    Jul 2004
    Vermont
    Re: Highsider
    -Suf Daddy
    Hey Scott -
  1. Winterizing!
    By Kitt in forum Bike Maintenance
    Last Post: 12-20-12, 09:16 PM
  2. winterizing a house
    By black in forum Off-Topic
    Last Post: 11-27-10, 06:34 AM
  3. Winterizing
    By Rambunctous in forum Pit Area
    Last Post: 09-23-09, 08:46 PM
  4. Winterizing the bike.
    By out thumped in forum Dirty Bastards
    Last Post: 12-05-07, 04:08 PM
  5. Winterizing Tips (again)
    Last Post: 10-16-07, 03:13 PM
