Except for the part about...
So even if they use Jeff's 1:17.7 as the benchmark (they probably won't) that means you can petition to bump if you're doing low 23's.Amateur can consistently run times within 107% of the fastest time (lap record) set in the corresponding Expert class may petition for early advancement.
If they use Mark Dages' 1:19.something, you're lookin at 25's
