Results 1 to 12 of 12
Brake Fluid reservoir for aftermarket master?
    Anyone got a spare?
    I have a stock Suzuki one, but apparently my new aftermarket master cylinder has a slightly smaller diameter connector. Anyone got one that would work for an Accossato master cylinder? One for a Brembo m/c would probably do the trick.
    I'm not about to go spend 60 frikkin bucks on THIS.
    I'll work a trade if you want a stock one.
    Lifer eboos's Avatar
    Re: Brake Fluid reservoir for aftermarket master?
    Just use the reservoir that you have and use 6mm or 1/4" tubing. The tubing will stretch to fit the reservoir.
    Derry NH
    What eboos said. 1/4" tubing will easily stretch over the reservoir fitting.
    10-4. After some quick research I ordered a couple feet of this in .25" inner diameter - Tygon 2075
    .25" = 6.35mm. Hopefully it'll stretch out to about 3/8" or 10mm on the reservoir side.
    I already have some similar tubing but the ID is to wide.
    Laws are for cagers!!! Turbocharged's Avatar
    Dec 2009
    North Central 'Assachusetts/Sometimes Metro-West
    It should stretch that far. Tygon is extremely flexible. I use .75" ID Tygon tubing for my liquid cooled PC, and the intake fitting on the pump is 1". It took some fighting, but it fit. Going from .25 to .375 should be easy.
    If life gives you lemons... Sue the motherfu**er!
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    One tip to tubing stretching is to use a hammer to soften up the end you want to stretch. It will warm up quickly and expand.
    Or I could just stick it down my pants.
    Careful that you don't get your weiner caught in the 6mm tubing.
    A couple feet? You planning on installing some ape hangers on the race bike?
    Uxbridge, MA
    HEY..PAY ATTENTION, Chuck....In 2 weeks you'll be asking what is the best one for your bike is
    Quote Originally Posted by FireboltEric_MA View Post
    Why do you think I bought a couple feet?
    Sep 2013
    Boston, MA
    I just bought a Brembo RCS 19 and I'm figuring out what to do for a reservoir/tubing. I'm happy to hear the 6mm tygon will stretch over the 8mm stock outlet on my SV650 reservoir, but the stocker is kinda faded so I might just buy a Brembo universal reservoir for like $15. If I buy one, which capacity should I go with (15, 30, or 45 mL)? I was leaning towards the 30..
  1. Replies: 5
    Last Post: 07-16-14, 07:32 PM
  2. WTB: 2nd gen SV front brake fluid reservoir
    By maxim_X in forum Wanted
    Last Post: 03-13-13, 10:20 AM
  3. brake reservoir tubing
    By NPDCPA in forum General Bike Related
    Last Post: 06-08-12, 10:10 PM
  4. WTB-Front brake reservoir
    By lopycam in forum Wanted
    Last Post: 09-09-11, 11:11 PM
  5. Brake Reservoir sock?
    By wingerdor in forum General Bike Related
    Last Post: 06-24-08, 04:27 PM
