Wow, that's a deal on that tail Degsy! I need one of those things for my YZF. Speaking of that, anyone need bodywork? I found a pretty competative site out there. The address is www.morsefiberglass.com. Double Apex picked up LP as a sponsor and even our discount pricing was more than they wanted for the tail I need.
Hey Degs....do we have to rejet???
Nope, don't have no jets!!!
I also just received my Akrapovic full Ti race system though, so we need soon to do some tuning work.
Anyone know a dyno shop that would donate some time and expertise in exchange for stickers on the bike?
Degsy
"Too bad ponies are assholes."
OXX
Milled out the part that holds the ignition switch and stamped NESR on it, and slightly polished the clamp. Looks more like a factory special piece now. Bling bling.
OXX
pic 2
OXX
Degs,
I sent ya a PM ya read it yet?
Thanks to Steve (snaggle) I have just snagged a set of world supersport HRC electrics for my racebike. Comes with HRC programmable ECU (no power commander needed), software for programming it, full HRC wiring loom (cuts out ignition switch and all lighting), HRC guages, adjustable tach and shift light etc etc etc. Woohoo!!!
Degs
OXX
HRC..........nice degs!
i'm gonna need you to get rid of my key/ignition set-up if you can. holla back when u get a chance...
peace
Glad you could get it. Sounds sweet!!, Does this mean we no longer have to figure out the total loss ignition?
'04 600RR
No, it means that we don't have to figure out how to bypass the ignition/lock unit. The kill switch on the right handlebar is now the ignition instead of the key assembly.
I decided against total loss ignition as it is too tricky and risky to use.
Here's the HRC electronics kit.
The item in the plastic bag is a new ECU. Wiring harness, Instruments, ECU with rubber mount, ECU mounting bracket and rubber strap, Ignition pulsar, kill switch, bank angle sensor, programming interface cable. This is the FIM race kit.
OXX
and yes, you read correctly, that tach goes up to 17000 rpm!!!
Degs
OXX
That is too cool!!!
Shift light..Heehee!!![]()
Chris J.
I am doing some major work on the bike this weekend. I will be reassembling the front end and putting the race exhaust system on as well as fitting my HRC electrics and probably starting the motor for the first time.
Any of you local peeps who want to swing by to help out and have a beer or two are welcome.
Degs
OXX
This is a kiddie weekend for me so I'm out,
2018 Harley Road Glide
2000 Ducati 900ss
2003 Harley Softail Deuce
Did some work this weekend.
Spencer (DaSpence) came over and helped me revalve the forks and put the front end back together. Couldn't install the exhaust system as it wouldn't fit with the bike on a stand so that will go on when the wheels are painted and refitted to the bike. The HRC electrics haven't arrived yet so that will have to wait also.
OXX
Spencer working on the F4i
OXX
From the right
OXX
..and left
OXX
Lookin' good Degs! Can't wait to get up there with the team. Have you received the Pit shirts yet?
'95 ZX7/9
'02 XR650R
'78 KZ1000
check on the NESR racing merchandise section.
degs
OXX
Yep it was a fun weekend working on the the F4i with Derek. I learned a lot with forks and tools and vocabulary of parts. We came to a few dead ends due to "special tools" but it worked out fine. Can't wait to work on the bike again.![]()
Why am I scared about this "special tool thing" ?
2000 Ducati 900ss
This is where I stand also... Frame swing arm and motor... Any of you RI guys going to be around this week???
G-man
Gerard
Dont worry Ed all it took was a rubber mallot and a flat head screw driver......the NESR "Special Tool".
Whew !![]()
2000 Ducati 900ss
