Today, since I have the day off, I decided to do a little maintanence on the M2. I wanted to get it cleaned up, fuel tank and float bowl drained and oil changed. I never really had to take off my belly pan since the drain bolt is still visible for tech, but when I took it off today, I was surprised with what I found.
For the past few weeks, I thought I was dragging my foot pegs. This was mostly happening in turns 3 and 6. I didn't so much feel it on my foot, just on the whole bike in general. When I took the belly pan off, I found that it was that that I was dragging all this time. The left side is almost worn through, and the right side is scuffing pretty good.
What can I do to fix this? I can't mount the pan any higher, it already is in hard contact with the exhaust. Can I go without the pan? I did last year for 1 race, and from what I hear it is more of a CCS requirement then a LRRS one.
a belly pan is always preffered, but buell=dry sump and tech never bothered our X1 about a belly pan.
get off the bike more so you're not draggin bodywork![]()
everyone not named ryan nicholson needs to get off the bike more so that is beside the point.
no, no. it was a joke. my fault for not bothering to put in the appropriate smilies.
Hopefully there will be some pictures that could help me see if I am getting off enough. I feel like I am getting off to the side, but maybe not low enough. Owens Racing Photos seemed to somehow skip me May 11th.
Ok, I think between you, me, and my friend we've enough to request a bodyposition seminar in the T1a pits Friday evening...
And no, 'bent over and grabbing my ankles' is not what I'm talking about.
Ryan= Not Mean
Ryan = Big Stud
Zip Tie Alley Racing #444
Signature edit by Tricky mike
ok, now that we are all done stroking ryan's ego. i think we need to get back to eric's problem. mostly that he is on an ancient tube framed buell that was never ment to lean that far anyway. eric, you need a hawk...just so happens i know a guy.![]()
Raise the rear and front ride height equally if you have a shock that allows for that. If not, you need one.
You could also try increasing the preload on the front and rear springs as long as you aren't making it too stiff.
I said too stiff, huh, huhuhuh, huh.
CCS LRRS #454
Gino had a couple seminars in 1a this past weekend.
Developing this bike was part of my plan for the season. Eventually, I will replace this bike, but I have a love for this bike that is beyond any explanation. This was the bike that I first learned to ride on, not even 3 years ago. This was the first motorcycle of any sort that I have ever been on. Having done product development in other industries, I enjoy taking something that shouldn't work and making it work.mostly that he is on an ancient tube framed buell that was never ment to lean that far anyway
i only poke fun at buells out of love. i really enjoyed the X1 on the track.
Eboos, can you shorten the mounting brackets and suck the belly pan in more?
how bad is it dragging? if it is not standing you or the bike up let it hit. My buell used to drag the belly pan pretty good, just stay in it and you'll be fine.
It's not standing up, I think that it has enough give. In turn six I am grinding it down pretty good. I am grinding the bottom outside rear edges. I can't get the pan any higher unless I figure out a way to get the exhaust a little higher in the back.
Can you cut off what is grinding?
No. I am grinding the pan surface. I may lay up a fiberglass replacement and do it with a little more clearance then the Buell Racing pan.
