Results 1 to 13 of 13
Gen 2 SV650 power loss in the rain.
    Jun 2012
    RI
    Hey guys,
    Yesterday at NHMS I was out during one of the wet races and my motor lost any power it had. Limped it into the pits... I've found some info online about a clogged drain for the front cylinder. Is there a remedy for this once I clean out the drain? Any sort of... shield?
    Thanks!
    642
    Posting Freak Scottg22's Avatar
    NH
    Clean out drain and replace the plug cap... be sure the seal is in place the best it can be. Plug caps seem to be a pretty regular failure in the rain. I tried to have a spare for Sam's SV
    Re: Gen 2 SV650 power loss in the rain.
    X2 drain hole and new cap problem solved
    Jun 2012
    RI
    thanks guys!
    642
    Ah, the infamous SV325.
    2016 BMW S1000XR
    Jun 2012
    RI
    And here I was thinking I couldn't get any slower!
    642
    So what you're saying is, he can run it against R3s and RC390s?
    Paging Kurlon.
    Gotta keep yer drain hole clean!
    i had that happen once. i think pete passed me and gave me a wtf look
    problem went away when i installed a fender
    edit: just realized you said 2nd gen, didnt those have a plastic flap that covered the front spark plug?
    Paging Kurlon.
    CCS single cylinder blind spot gets you into just about every class other than anything Supersport, Supertwins, or Formula 300. You can run Ultralight 300 but your points will not count for the ROC in Daytona as you'd exceed the 310cc limit on singles in Ultralight Thunderbike.
    Lifer golden chicken's Avatar
    Attleboro, MA
    Yes, but that little flap doesn't do enough if it's wet enough. Water can still get through the radiator (and around the flap) and down onto the front plug.
    I loled
  1. Wanted - Parts & Tools | Looking for some rain take offs for an SV650
    By Philkinson in forum Wanted
    Last Post: 12-05-16, 10:14 PM
  2. Intermittent electrical power loss to no power at all
    By bmx9854 in forum Bike Maintenance
    Last Post: 07-08-15, 09:30 AM
  3. Loss of power after doing -2/0 on sprocket change?
    By luukasama in forum Bike Maintenance
    Last Post: 05-31-13, 03:23 PM
  4. sv650 rims and rain tires
    By 388 in forum For Sale
    Last Post: 05-17-12, 01:57 PM
  5. Power Loss at 10k
    By RyanNicholson in forum Bike Maintenance
    Last Post: 08-17-08, 10:58 AM
