Results 1 to 23 of 23
Gino's 2010 Last race ULSB race and Ultimate Goal Met
    Talking Gino's 2010 Last race ULSB race and Ultimate Goal Met
    I got a little bit of the racing bug towards the end of the season. I ran the last 3 race weekends. What got me going was Chis D. accident. I wanted to have you all pony up some money so I found a loop hole. The last time I ran with a stock motor I was in the 1:22.7. So I figured if I could beat that time on a stock motor we could help Chris out. I did that within the first practice session on Saturday. I thank you for paying up. If you did not hear Chris made an appearance at Saturday's riders meeting. It was emotional. It was wonderful to see him up and about.
    Well I was getting coaxed all season by 6 to find the 19's on a stock motored Hawk. I was swaying in the wind whether it was going to happen this year. Typical output of a Hawk is somewhere between 43-50 hp. He wanted to be the first to the 19's but he had some engine issues. Sorry brother. I knew it was going to be a lot of work to accomplish this.
    This past weekend I really did not want to buy a new set of B-stones for the last race weekend and let them sit over winter knowing I get about 3 race weekends out of a set of tires. I made it thru the 2 Friday practice sessions and was not feeling all that confident about the tires. They were really getting torn up and letting me know that I was going to run some slow time in ULSB. I only broke into the 1.22's. Well I went and got a new set mounted. Thanks Miles and Radu from Street and Comp.
    ULSB:
    Green flag drops and I get a marginal start. It is just all Motards and Mike Dube on his honking Duc 800. Motards now rule ULSB. I hang out on the outside and pick off a couple in T1 and get on the inside of T1A. 2 down, 5 to go. There are just 2 Motards and a big Duc 800 in front of me. They are keeping a tight formation and running a freight train. I do not want to be the caboose of this train wreck. I have places to go. Jason Cavanaugh 451 is right in front of me. I saw what he did in lap 1 and 2 and hoped he would do the same on lap 3. As I set up for T3 he started to go tru the same motions. I took advantage of this and set up the inside of T3 to T4 line. Excuse me, coming thru.
    Next was the big Duc with Dube on it. Dube was doing the whole follow the leader with Block, Eric 922 on a motard. I cannot sit back here. I got to make a move. He's got a ton of motor on the straights. How am I going got do this. Having ridden with Mike for many years I have knowledge of what he can and cannot do. Lap 4 I pulled the trigger. I set up the run in T1-2 and it got me on his back tire to catch a little draft to somewhat stick with him. Yea right. I closed on him under the brakes and he took the line I thought he was going to take. I instantly set up the run under him. With a fist full of throttle I was next to him at the apex of T4. I love it when a plan comes together. I keep to the left side a little to try and shut the inevitable down. Yea right, the big motor awakes as we crest the hill and he blasts right past me on the left. He tries to shut down the inside line (Left) into T6 but he left the door open just a crack. Maybe about 3'. It was enough for me to squeak on by under brakes and past him. Somehow I had to make the turn. I crank the bike over so far my boot toe slider was dragging. I then somehow had to keep him on the outside of me thru T6. Using all my power I tried to maintain the inside line of T6 and get to the T7 first. It worked. I nailed T9 and the section thru 11-12 as best as I could to make up some ground on the big Duc. It must have worked. I never saw him the rest of the race.
    Then there was Eric Block 922. With that run from Dube I was able to set up a drive out of T12 and catch a draft on the outside of Block. He had the inside of T1. Knowing I would not be able to get this section I sacrificed this turn for another. I settled back so I could learn how he rides. I've never ridden with him before so I wanted to pick something up. I keep on him thru 1-2 and thru 3-5. In T6 I notice what line he is going with. "I've got him." I take the inside and block the potential run that he may have underneath me. I hold on and again rip thru T9 and 12. By the lap times this pass got me into the first set of 19's. With the free and clear running room I had my eyes set on Martire. I never thought I would have said that before. Last lap. Mike take a peek back and sees me. HI MIKE... I get up on the right side of his back tire out of T4 but he just motors on over and puts a good gap on me. Next.... I've got a couple of chances here. T9 or T11. I get a great run out of T6-T7. I'm closing in . I've got a pretty good shot in T9 I go for it. I run the outside and get to the flop for T10. Not enough room. I roll off and concede to holding onto my position as I knew I did not have a drive to make anything happen in T11-12 let alone any power to make it around him in down the straight. I did my best and stayed in his draft and finished .2 behind him. What a great race. It sure kept me busy and on my game. Wish I had 1 more lap. Just maybe. .
    I roll into the pits and DDK is there wondering if I wanted to know what I did for lap times. He brings it up and. YEA MOTHER FER....... F N YEA.. 1.19.4 MOTHER Fer. Game Set Match. I met my ultimate goal of getting a stock motored HAWK into the 19's.
    Here are the results for my 2010 3 race season.
    8-7-2010
    ULSB 8th 1.20.9
    LW Sportsman 6th 1.20.7
    9-4-2010
    ULSB 5th 1.20.6
    LW 4th Sportsman 1.20.6
    10-2-2010
    ULSB 3rd 1.19.4
    LW 5th Sportsman 1.19.8
    Not shabby for a crusty racer.
    I beat DOC by 1 point in ULSB Wooooo Hooooooo
    Re: Gino's 2010 Last race ULSB race and Ultimate Goal Met
    Awesome job Gino. It was great to see you at the track this year and 19's on a stock motor if friggin awesome, that shows some serious skill..
    does this mean you'll be dicing it up next year? as long as the bug doesn't go away this winter?
    Lifer Pittenger5's Avatar
    Austin
    Go Gino Go!
    Zip Tie Alley #505
    Ambition Outweighs Talent strgt's Avatar
    Jun 2009
    Damn Gino that is insane! Congrats on meeting your goal.
    www.streetandcomp.com
    LRRS/CCS/WERA Am. #290
    NESBA Adv. #290
    Well done... now if you can just downgrade the suspension, put on some weight and drop 17s like a certain crap bike is purported to do...
    It's one thing to drop those lap times on a clean track, but another thing entirely to out maneuver machines matching you on suspension but out motoring you. Well done.
    Teens is pretty sick on anything. Congrats on dropping em on an antique.
    Jan 2009
    Waltham
    Wirelessly posted (Tilt: HTC-ST7377/2.10.502.4 (93577) Opera/9.7 (Windows NT 5.1; U; en))
    Nice A* team quote, you painted a vivid picture, congrats on your teens
    Rochester, NH
    Go Gino Go!
    Great write-up Gino!
    Roland Arsenault
    LRRS and USCRA #763
    This is how you do 19's and still have fun with the spectators in the bowl:
    KB KB's Avatar
    Manchester NH
    Nice pic Chuck
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Posting Freak Yknot's Avatar
    Derry, NH
    Quote Originally Posted by 07BladeRider View Post
    We are just not worthy..
    Great job Gino!
    CCS #68
    2016 Husky FS450
    Huge thanks for all the support from MotoSport
    Just Registered Doc's Avatar
    Jericho, VT
    Go Gino Go! (TM) YOU DA MAN!
    I knew I shoulda raced the last weekend just to keep my points lead! Oh well, you deserve it Gino Congrats.
    (Friggin 19's on a stock motored Hawk...mumble, mumble, the man is a machine, mumble, mumble, I can't even break into the teens with 20HP on him... mumble, mumble... Maybe I should go back to a Ducati... wait, he still has my Techno... If I could buy that back... Oh christ what happens when he comes back with the race motor AND the FCR's I sold him?!... I gotta do a trackday with him and try and glean some knowledge... )
    Wait a minute? Since when did Andy have a stock motor in his Hawk?
    Like I told you at the track...you are nuts dude haha. Congrats again!
    Rochester, NH
    I hear a rumor that Gino was taking a nap while turning laps with young Jake this week. Nice one Gino!
    Roland Arsenault
    LRRS and USCRA #763
    Ahh why not! lrrs428's Avatar
    Oct 2007
    Littleton NH
    Ginoooooo!
    SWEEET Gino.
    The Legend still got it
    Member JudyGT's Avatar
    Windham NH
    great job Gino,
    Like they say, anything in the "teens" is awesome..and you are NOT an old timer!
    Haverhill, MA
    Great run Gino!
    Always good to read about your racecraft and see that there is another side to racing then just the twisting of the throttle.
    Joel
    I like to think racing is 90% mental and 10% mechanical.
    Wirelessly posted (Samsung Lube.... Er, Glyde: BlackBerry8520/4.6.1.314 Profile/MIDP-2.0 Configuration/CLDC-1.1 VendorID/102)
    Don't forget 32% balls
    ....... Nazo's Avatar
    Jul 2004
    Good job bro, good seeing you dice it out this season.
    Chris
    LRRS Expert #160
    Jul 2004
    Chris
    LRRS Expert #160
  1. Doc's Race report 8/22 #116 ULSB
    By Doc in forum Race Reports
    Last Post: 08-25-09, 09:12 AM
  2. APRIL 09 ULSB Race reports.
    By Doc in forum Pit Area
    Last Post: 05-01-09, 05:20 AM
  3. 08 LRRS #7 ULSB Gino's RR for win#5
    By nt650hawk in forum Pit Area
    Last Post: 09-06-08, 11:58 AM
  4. April 08 ULSB Gino race weekend
    Last Post: 05-08-08, 07:11 AM
  5. Gino's Race report Sept 2 EX ULSB
    Last Post: 09-05-07, 01:02 PM
