Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
Motor work, mod & overall racing advice wanted
    Re: Motor work, mod & overall racing advice wanted
    Dumb question, but you have ever seen a pro rider using a wave rotor for competition? Usually not. Maybe for photo shoots.
    Why not check into Brembo or Braketech rotors? (damn those Braketech creamic rotors are sweet, but $1100 EACH for the fronts.)
    Just Registered 13's Avatar
    Dec 2003
    Auburn, NH
    I've built sweet Subaru engines. How hard can an SV engine be?
    One of the former LRRS #13's
    http://www.facebook.com/ChrisWatt762
    JT42
    Just Registered Doc's Avatar
    Jericho, VT
    Quote Originally Posted by 07BladeRider View Post
    Ya know... I have never thought of that.
    I do know my wave rotors stop better than my stockers.
    Actually yes, I have... just not the factory boys. I believe there are even some World Supersport guys running the Wave Rotors.
    Pete, for what it's worth, I can get you a deal on Braketech stuff too
    CCS/LRRS #83
    Meriden, Ct
    Pete... I can get either one of those cheaper than that for you...
    Lifer DuncanMoto's Avatar
    Can you still???
    I think I got Pete covered on the rotors.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    Quote Originally Posted by DuncanMoto View Post
    Can you still???
    dick!
    PS... I can get them cheaper than you!
    but unless pete is riding a baby blue and black bike, he's on his own.
    I would never ride a baby black and blue.... that's just sick.
    Wait, what?
    6.1.2 All motorcycles must meet the following requirements in addition to the
    applicable requirements in Section 5.
    A. Original equipment wheels, brake calipers, forks, frame, engine, fuel
    induction system, and swing arm must be used.
    Cut whatever you can off the sub frame. Or make you own.
    (1) 18” wheels may be replaced with 17” wheels of the same width.
    (2) 16” wheels may be replaced with 17” wheels of the same width.
    (3) Rear swing arms on OEM Belt drive motorcycles may be
    replaced to convert final drive assembly from belt to chain drive.
    B. Aftermarket brake rotors may be used but must be the same
    dimensions as the originals and must be made of a ferrous material.
    ABM Full Floating. ===Less resistance between the Pad and Rotor which gives you a better feel of the tire to pavement.===
    Go see Ted
    Non-current motorcycles may use brake rotors up to the same size
    as those that come as original equipment on the current model machine.
    (1) Aftermarket brake cooling ducts or wind deflectors are prohibited in
    Supersport
    C. Any fairing may be used provided it is made of plastic, fiberglass or
    carbon fiber and it meets the requirements in Section 5..
    D. Original equipment air box must remain as produced. Air filters must
    be used but may be Aftermarket units. Aftermarket air filters are
    restricted to units available via normal commercial channels and
    designed to mount in the stock location for that specific model
    machine.
    Aftermarket air filter units that replace part of the OEM. air box are
    required to maintain the original size and number of air inlet openings
    as the stock unit. (Are they talking about the Air filter here, Yes, NO?)
    Does this mean that you can take the top off of you air box?
    RAM AIR plumbing to the box!
    E. Engine modifications include the following:
    (1.) Pistons which are no larger than 1mm over stock size may be
    used but must be same compression ratio as the OEM piston.
    (2.) Original equipment cylinders must be used.
    Coated to reduce friction
    (3.) Original equipment head, valves, and cams must remain as
    produced, with the exception of machining the gasket surface of
    the cylinder head.
    Gaskets
    Stronger Valve springs
    Ti caps and retainers
    Slotted cam gear.
    (4.) Original equipment cases, crankshaft, and connecting rods must
    remain as produced.
    (5.) Original equipment transmission gears must be used.
    (6.) Carburetor bodies and/or throttle bodies may not be modified,
    bored, or polished.
    DAMN
    F. Internal engine modifications on all single cylinder machines,
    4-stroke twin cylinder machines with less than 4 valves per cylinder
    produced prior to the 1999 model year., and all twin cylinder machines
    produced prior to the 1994 model year are unlimited, provided class
    displacement limits are not exceeded.
    G. Aftermarket carburetors may be used on single cylinder machines,
    all 4-stroke twin cylinder machines with less than 4 valves per
    cylinder, and all twin cylinder 4-stroke machines produced prior to the
    1994 model year. 6.1.2. D. is waived for single cylinder and all twin
    cylinder 4-stroke machines produced prior to the 1999 model year.
    GET A HAWK
    H. Tires must be DOT approved.
    (1.) If the Race Director declares a “Wet” event, commercially available
    rain tires may be used in place of DOT approved tires for the
    remainder of that race day.
    Leg strengt training
    Diet.
    Seat time.
    Think you've got the PC and Full Pipe
    Pete you impressed me this year and did Extremely well this season. Can't wait to see what you have in store this season.
    Member DerekSBelanger's Avatar
    Worcester, MA
    ....and thats why we all like Gino.
    I'd think that whatever you choose to upgrade, it would be important to make sure you have $$ for a full season of racing (consumables, maintenacne and repairs) before spending on anything else. Cant score points if you aint on the track.
    Are you laughing because its pink? Thats awesome because it makes me laugh too!
    Quote Originally Posted by DerekSBelanger View Post
    ....and thats why we all love Gino.
    Ficksed And thanks, Gino, I'm excited, too
    ABM rotors, eh? Better than Galfer Waves?
    Oh Ted... Price check for ABM part number 114-01546-19 times two, please?
    Also note, while they say certain head bits must match OEM, they don't say anything about keeping them in the same place...
    Check to see if Suzuki offers OEM oversize valves for repair.
    Check the grind profiles of different year intake and exhaust cams, might be worth while to run an intake cam in the exhaust for a bit more lift/duration?
    08 SV650s got dual spark heads, possibly 07s as well.
    It'd be worth asking Eric at CCS weather or not the SFV650 (Gladius) counts as in the same model line as the SV650 (given that it's replaced it in Suzuki's line up, same engine, etc, and even Suzuki Corp calls it an SV replacement I'd think so...) as it appears the Gladius has lighter wheels, and the engine might have some minor tweaks worth backporting to your SV.
    Edit:
    Throttle bodies changed for the 'k7'/07 models...?
    KEY POINT Thanks D. If you don't race you can do well.
    anyone want to ride with me....
    So I FINALLY tore into the SV yesterday...
    pulled off the forks,
    yanked the shock,
    trimmed my subframe to save weight,
    Popped off the airbox & now have my eyes on the emissions system and wiring harness which are both still fully intact.
    I think I'm going to hold off on motor work this year. I'm gonna concentrate on chassis/suspension work & place an order for a Quickshifter at some point in the near future.
    And I've got some Galfer rotors waiting for me at DuncanMoto. I was considering going with the AFM's so I could be like Gino, but Ted had already placed the order. I supposed I could sell them & get some AFM's. Gino, think it's worth the trouble?
    Pete, no it's not worth the trouble ya nunce!
    CCS/LRRS #83
    ... But I wanna be like Gino
    Meriden, Ct
    So that's what the Vemar is reduced to huh?
    Done (or being done) for 2010:
    Galfer rotors
    Keyless ignition (just need a 30a switch and a 100ohm 1/2w resistor)
    Keyless gas cap (just ordered one of these)
    Removed PAIR emissions system to simplify things under the "hood" & shed a little weight
    Dynojet Quickshifter
    Trimmed my subframe
    Had my Ohlins shock rebuilt by GMD
    Had my fork internals completely pimped by GMD
    Woodcraft Clip-ons to rep the sponsors!
    Still need to order up a little Shear pin for my Scotts damper... It's a little tiny $3.95 part that Scotts wants $10.90 to ship via UPS ground
    Senior Member spydah's Avatar
    Fitchburg, MA
    sweet! Thanks for telling me what I need to do to be on par machine wise.. Now I just need to get more skills ;-)
    LRRS #831 Novice
    2007 Ducati 1098 - Street (okay, sometimes track)
    2002 Suzuki sv650 - Pure track!
    2007 Suzuki sv650 - Next seasons track bike
    http://www.myspace.com/spydah77
  1. Wanted - Parts & Tools | WANTED: Gen 1 SV 650 motor
    By Viper897 in forum Wanted
    Last Post: 05-11-16, 06:32 AM
  2. Wanted Honda 400 four motor
    By 6 Fingered Man in forum For Sale
    Last Post: 03-19-09, 01:39 PM
  3. Wanted! CRF450 motor
    By Awesome in forum For Sale
    Last Post: 12-23-08, 04:42 PM
  4. Putting bike together. Need advice on motor
    By ftrain in forum Bike Maintenance
    Last Post: 09-05-05, 08:58 PM
  5. Motor work, looking for experts
    By Degsy in forum Pit Area
    Last Post: 07-23-02, 01:00 PM
