Results 1 to 12 of 12
Question about the front tire for the racers
    Petrol sniffer MC's Avatar
    Lebanon, NH
    I've been wondering about this for quite some time, so I thought it's time to ask those in the know. Why is it that on my bike (and many others) with street tires, the rear tire is worn all the way to the edges, while the front has virign rubber down both sides? Is this a safety margin built in by the tire manufacturers to prevent a front-end tuck? Is it that the bikes still have more lean angle being unused? Is it something to do with the suspension set-up of streetbikes?
    Help end the ignorance!
    '01 VFR 800
    Fo Shizzle LM954RR's Avatar
    Oct 2002
    NC
    Suspension setup, speed and the amount of countersteer needed to make the bike turn at speeds is what determines how far to the edge of the front tire, the wear extends. Lean angle alone determines the usage out back. simply put.
    That is disregarding rake angles, ride hight, tire profile, and a few other more complicated aspects of motorcycle geometry.
    Take a new set of tires and go to your favorite sweeper.
    hypothetically speaking, at 80mph, the bike at a lean angle which causes the pegs to just scrape, will bring the contact area of the rear to the edge, and leave a 1/4 inch unused in the front.
    The same sweeper, only this time 100mph, with the same lean to the pegs, will require more countersteer, causing more fork compression and greater rake in front, bringing the contact area to near edge. While only using the same contact area on the rear.
    ********* **** Racing
    LRRS #293
    Dic on
    Lew, you are one smart mother-fucker!!
    "Too bad ponies are assholes."
    OXX
    Oct 2002
    NC
    I would trade that title for "One Fast Mutha Fukkah"
    LRRS #293
    Diamond Geezer Kip's Avatar
    Nov 2002
    Cranston ,RI
    Take this info. from Lew a guy who struggled to do 1:19's all year and Degsy chimmes in giving his 2 cents when he can't even speak english. Ask Peter at GMD he should give you a good reply back.
    Nov 2002
    Cranston ,RI
    I forgot to mention I went drinking with Jeward lastnight. Now lets "Give it a name".
    Dec 2003
    Ma
    topic stealer!
    http://www.nestreetriders.com/forum/...threadid=12651
    So the answer to my question is, I can go faster?
    the phear hohum's Avatar
    Jul 2002
    Everett, MA
    You can always go faster... until you crash
    Lebanon, NH
    Originally posted by hessogood
    topic stealer!
    What can I say? I was just wondering why tires are designed this way. With the tendency on the street for people to panic-grab the brakes and lose the front end in a corner when they overreact, I'd think that, FOR THE STREET, front tires would have a different profile to put some of that virgin rubber under the front as a larger contact patch to help avoid a lowside.
    <In my best New York accent>
    Welcome to Caowfee Taowk...DISCUSS!
    '01 VFR 800
    Dec 2003
    Ma
    In regards to grabbing the front brake during a turn due to panic, I'll relay the single best advice I've ever been given in regards to riding
    never cover the front brake anywhere near the turns
    think it was Gram that said this
    Super Moderator legalspeed's Avatar
    Somersworth, NH
    That's why it is designed that way, If you apply the converse, when you panic grab, for an instant your front profile is using all the geometry, as if you went in at 100 like stated above.
    Look at it this way; say we go with your profile engineering, when pour Lew hits the corner at 100, he runs out of contact and in turn hits the pavement; because your tire geometry is designed for maximum contact at 50-80mph corners.
    GMD Computrac is a great place to start learning about bike geometry, suspension, and riding dynamics. We even have an all day seminar open to NESR members this Saturday.
    LRRS\CCS\WERA #486
    Lebanon, NH
    That's specificly why I said "FOR THE STREET". Anyone cornering at full lean at 100mph on public roads obviously isn't concerned about safety and shouldn't be on the road. That's the point when you should have already taken it to the track.
    '01 VFR 800
  1. My front tire is fatter than your rear tire
    By RevHappy in forum General Bike Related
    Last Post: 10-31-04, 04:11 AM
  2. Question for you racers.....
    By bigred875 in forum Pit Area
    Last Post: 05-07-04, 08:37 AM
  3. Front tire (race)
    By PinHead in forum Pit Area
    Last Post: 05-02-03, 05:08 AM
