Results 51 to 75 of 101
Where do you shift?
  1. #51
    Dec 2003
    Ma
    Where do you shift?
    Does the same go for the supersports?
    I'm considering putting a slipper in my bone stock '03 600RR. What changes to my riding will I be making, how will the bike feel different (better/worse) and is it worth it.
  2. #52
    Where do you shift?
    I'll pop my dirt bike down a gear without the clutch if I find myself suddenly going too slow... like maybe up a rocky climb... and there's just too much else going on to worry about the clutch.
    I NEVER downshift my streetbikes without the clutch. I just don't see the benefit.
    And blipping the throttle while braking (without pulling in the clutch) sounds like you'd get some "lurching"?
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
  3. #53
    It never got fast enough rebelpacket's Avatar
    Jul 2003
    Bozeman, MT
    Where do you shift?
    [/B]
    Yes yes.. but what if your street bike just so happened to be a dirtbike?
    I will admit, the motard stops faster than I can shift. Going into 3, its almost as if I slow down faster than I can pull in the clutch, bang down four gears, and let out the clutch.
  4. #54
    Where do you shift?
    Tony, if you don't do it right & over-blip, yeah, you'll get a little lurch... but if you get it right it's amazingly smooth.... unfortunately it's pretty tricky & takes up some of your thought processing to get it right... but when it works it's a great feeling.
    It's a nasty habbit I've formed as a lazy man's way of reducing armp pump in my clutch hand during GT's when I first started racing... that was my benefit... But beacause I'm not consistantly smooth with it I don't clutchless downshift if I'm leaned way over. I get it done before I'm gettin close to full lean... you can see my shift points on my map above.
    Getting back to being proficient w/ the clutch so i can downshift smoother while leaned way over is one of the #1 things i'm gonna work on in '07. When your times are within 105% of the top experts in your class, it's definitely gonna start holding you back.
  5. #55
    Where do you shift?
    Another reason I use the clutch is because I like the feeling of the engine braking AFTER I've started leaning into the corner.
    In other words, I'll do the actual downshifting while mostly straight up and down, but I don't let the clutch fully out until I'm leaned over.
    So I'm still trail braking (which slows the front), but I'm also feeding out the clutch (which slows the rear).
    Not saying this is fast or right... just my way and I'm too damn old to change it now.
    Having never had a transmission problem and never low siding entering a corner ... I'll stick with it.
    Tony
  6. #56
    Where do you shift?
    do you still rev match while braking? or do you really use that rotational differential (or whatever you wanna call it) & just use that right hand for braking?
  7. #57
    Where do you shift?
    I used to rev match on my 95 CBR F3.
    Then I switched to 2-strokes (TZ250) and found out you didn't need to blip the throttle.
    Then I came back to 4-strokes (CBR600 RR), and the transmissions and clutches had gotten so good that I don't notice any benefit to blipping anymore.
    Tony
  8. #58
    Where do you shift?
    My 636 doesn't have a slipper in it, so as I grab downshifts, I blip the throttle. I have no problems using the lever as the slipper. It's just much easier with the actual "back torque limiter".
    Jay, same deal for big bikes too. Just kick it
    Mike 37
  9. #59
    Where do you shift?
    Agreed, It's much smoother for me to not use the clutch, ever... Even on Tony's streetbike I don't use the clutch...
    Lifer Evil_Weasel's Avatar
    Over the Highside
    Where do you shift?
    when i switched from a 4-stroke to a 2-stroke i was origionally concerned with the lack of engine braking. afew people mentioned how weird it is or how strange it felt and i propbably wouldn't like it, it would take for ever to get used to, etc. after about 2 laps i was in love. braking and down shifting is so much easier to do smoothly. on the buell it was full cluctch and a huge blip for every shift and deal with the massive engine braking as best you can (be your own slipper clutch). with the buell i was in the same boat as alex....i could slow the bike with the brakes faster than i could smoothly down shift. on the NSR it's fan the clutch, and shift....that's it. no rear wheel hopping, no back end trying to pass the front. i can deffinatly concentrate more on my braking and less on my down shifting now.
    yay two-strokes!!!
    Where do you shift?
    i apply just enough clutch pressure for it work (shifting up or down) i dont have to blip much since my bike idles at or above 3K
  12. #62
    Jul 2006
    Western Mass
    Where do you shift?
    So do racers with a slipper clutch notice an advantage (lap times)than without? It would seem as though a racer could focus on his/her brake markers, turn in markers, etc. without having to worry about locking up the back end.
    Where do you shift?
    Absolutely... given the choice, the slipper is going to be the way to go.
    When all goes right, you may not need it.
    But when the shit hits the fan and you're in the heat of battle, you sometimes don't exactly use proper technique... so a little help from the engineers is nice.
    Tony
  14. #64
    Just Registered Doc's Avatar
    Jericho, VT
    Where do you shift?
    This is how I run it.
    88 Honda Hawk
    Stock gearing (16/44)
    I try to do it just like this, but I think I have taller gearing 16/45
  15. #65
    KB KB's Avatar
    Manchester NH
    Where do you shift?
    I dunno i see Johnny Gosselin just hammering the gear shifter coming into the bowl and 3 and anywhere really and instead of it locking up it just goes nice and smooth. I think i want a slipper. I go from 5th to 3rd while on the brakes into 3, bang 2 gears let the clutch out smooth while trail braking to the apex, whack the throttle up to 4. Maybe the slipper would be nice no clutch brake and bang the shifter?
    LRRS/CCS EX #13
    GMD COMPUTRACK
  16. #66
    KB KB's Avatar
    Manchester NH
    Where do you shift?
    Doesn't the 600rr come with the, and I quote NAZO on this "kind of like a slipper clutch"??????
    LRRS/CCS EX #13
    GMD COMPUTRACK
  17. #67
    Where do you shift?
    actually a 45 would be shorter
  18. #68
    Where do you shift?
    ok. after this weekend ive changed some stuff.
    SV6
    14/44
  19. #69
    Jericho, VT
    Where do you shift?
    Ok then shorter...
    Paid more attention this weekend.
  20. #70
    Lifer oreo_n2's Avatar
    Mar 2002
    Amherst, NH
    Where do you shift?
    KTM SMR 560... 6 speed. I like seeing the other 6 speed thumper shift points. they are NOTHING AT ALL like the 4 speed yz450 shift points i was using.
    Its taking me quite a while to figure out when and where to shift with this bike. Alex... you shift to some real low gears man. Probably why you pull me on the exits so often.
    i was talking with graham about it a while back and he kept saying lug it with higher corner speed. at the last track day i worked out a shift and corner speed combo that felt better than anything else to date that looked like this...
    Quote Originally Posted by rebelpacket View Post
    Goddamnit. I shift EVERYWHERE on that damn 'tard. I'm probrobly doing something wrong...
    Brent LRRS #772
    2006 KTM 560 SMR
  21. #71
    Foxboro, MA
    Where do you shift?
    Quote Originally Posted by 35racer View Post
    I know the number of shifts is right... but they all might be one gear higher?
    Honda 600rr -1 in front, +1 in back from stock
    +1 - I don't feel like re-doing the map and this is me too
    I'm on a 2001 R6 15-48 gearing (-1 front, stock rear)
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
  22. #72
  23. #73
    Lifer s a x m a n's Avatar
    Mar 2003
    Lee, MA
    Where do you shift?
    Quote Originally Posted by mmracer37 View Post
    Jay, most of the guys running Hondas are using a 48. The only problem you gotta watch for is chain length/tire clearance. With the 48, if you try to keep the wheel as far forward as possible, the tire will rub on the shock linkage. It also depends on the tire manufacturer too. Just pay attention when you put it together.
    is this -1 in the front as well when running the 48???
    Lifer RyanNicholson's Avatar
    Canterbury, NH
    Where do you shift?
    right now....my shift points are a little busy....i'm gunna go up to 49 or 50 teeth in the back to keep 3rd gear in the powerband around more of the track but this is what i was running this year....
    2nd to 3rd to 4th on the straight
    down to 2nd going into T1
    up to 3rd exiting T2
    town to 2nd into T3
    up to 3rd exiting T4
    down to 2nd into T6
    up to 3rd exiting T6
    down to 2nd into T11
    sometimes I only get in 1 downshift into T1 so i have to go from 3rd to 2nd between 1A and T2
    Jericho, VT
    Re: Where do you shift?
    Bumpity as requested...
  1. Broken Shift rod
    By ducatirdr in forum Pit Area
    Last Post: 04-17-17, 01:33 PM
  2. GP Shift
    By Petorius in forum Pit Area
    Last Post: 09-18-15, 11:17 PM
  3. Replies: 5
    Last Post: 04-25-14, 10:43 PM
  4. GP shift?
    By Awesome in forum Pit Area
    Last Post: 05-05-05, 05:07 PM
  5. GP Shift
    By snaggle in forum Bike Maintenance
    Last Post: 07-18-04, 12:30 AM
