Results 1 to 25 of 34
do slicks really last longer/wear better?
    Just Registered kermita's Avatar
    Mar 2007
    RI
    Is it true that slicks last longer/wear better than street tires for track-only use? I heard this recently but no one had a definitive answer as to why.
    -kim
    drz400sm
    http://farm3.static.flickr.com/2473/3532494258_79ceb54614.jpg
    Just Registered Doc's Avatar
    Jericho, VT
    Re: do slicks really last longer/wear better?
    No.
    Lifer a13x's Avatar
    May 2005
    Escondido, CA
    Trick-question.
    Boston --> San Diego
    Mar 2007
    RI
    Trick-question.
    how so?
    -kim
    drz400sm
    Sep 2006
    Around the corner
    O shit K you opened up another chance for Oreo to take us to school
    Take it away OREO ...................................................
    The rule is:
    Photoshop.
    Seriously though, if they did everyone would probably be using them.
    EDIT: Apparently you've been schooled?
    -Pete LRRS/CCS #82 - ECK Racing, TonysTrackDays, Ironstone Ventures
    GMD Computrack Boston | Pine Motorparts/PBE Specialists | Phoenix Graphics | Woodcraft | Street & Competition | MTag-Pirelli | OnTrack Media
    Sep 2006
    Around the corner
    you must be tired
    I was expecting a two page dissertation as to why this is not true
    I actually like most of your answers
    The rule is:
    Mar 2007
    RI
    Right...but most people use their bikes for both track and on the street making slicks a less appealing option. I realize that not all racers use slicks but not all race classes allow them. I thought perhaps it has something to do with heat cycles...that slicks and more race-oriented tires were better constructed to deal with high heat followed by continuous cool downs. Is this not the case?
    -kim
    drz400sm
    Sep 2006
    Around the corner
    Hey K check out this thread if you havn't already http://www.nestreetriders.com/forum/...-med-comp.html
    The rule is:
    Well here's my theory...
    slicks are designed with pretty much one thing in mind... maximum traction under maximum torture. As such, longevity takes a serious back seat in the design stages. Slicks are soft, high-heat tires that have a very short life when ridden the way they were intended. Of course if they were DOTs or Street tires, they'd probably be shreded long before a slick at that kinda pace.
    The reason why I probably wouldn't use slicks on the street if it were dry out (& it were legal), is that it's tough to get em up to operating temp under those conditions. It'll last a helluva lot longer than it would if it were being ridden on the track, but if a tire isn't up to temp it's not gonna be working at its full potential. I'm not even so sure I could get a slick fully up to its operating temp during a typical track day. Under race conditions, maybe, but not at a track day where I'm only riding at about 90%. Now it may provide more traction at that temp than a DOT race tire, but I'm not so sure. I'd have to try em out back to back, & do some testing to know for sure.
    Even my Dragon Supercorsas are a little slick in that first mile or two and no matter how long I ride them on the street they're still not as sticky as they are on the track where they're put under more stress from hard acceleration & braking.
    That answer a little better?
    Basically when ridden the way they were intended, they have a pretty short life... but they were meant to take more stress than a DOT race or a street tire, which would shred.
    Ride em easier & they'll last a lot longer, but may not get up to operating temp & give you maximum traction.
    Where the traction vs longevity lines cross to make it worth switching to slicks depending on your pace, I don't know.
    I'm more interested in what Dave (Karaya One) has to add since I dont have any real experience w/ em other than on Degsy's 600RR.
    Dic on
    No.
    Yes, ....sometimes.
    It IS a trick question, because it depends on the rider.
    1st scenario. I'm out there doing track duty in the blue group. Someone quite fast (say 1:20 pace) wants me to follow them and critique them or offer advice. I'm on street tires. I can keep up that pace on streets for a few laps, then the street tires overheat and I'll tear them up pronto.
    2nd Scenario, same as first but I'm on medium compound slicks. I can stay with the guy for much longer without damaging the tires.
    I have said it before and I'm not lying here. I have a set of slicks at home from the 600RR that have at least 750 miles on them (maybe more). They are not torn up and they have plenty of tread left. I don't use warmers. I just keep the acceleration to a minimum for the first lap or so to warm them up. I pay very close attention to tire pressure and I ride smoothly.
    ymmv
    "Too bad ponies are assholes."
    OXX
    Good point.
    So the money question is, do ya think slicks would last longer & offer a comparable amount of traction compared to Kermita's current tire at her pace? Where do those curves that represent longevity & traction benefit the rider as they pick up their pace?
    btw, edited my post above a little after doin some more brain storming.
    Slicks often last longer, and it may simply be that they have no cuts in the tread making the surface less prone to tearing...
    I ran two sets of slicks in 2007. 7 Track days and 5 races and practice sessions W/out issues.
    I have also ran a set of Bridgestones on the 929 for 7500 miles and 5 trackdays.
    Key is to being smooth no matter what you're on.
    If I had rains or DOT's readily available... mounted up on spare rims... then I'd probably run slicks for track days. (given my pace)
    For the average rider doing trackdays, without spare rims ready to go... slicks mean that if it rains you are sitting in the garage and/or swapping tires.
    With Street and Comp planning to be at our events to change tires, that might not be terrible.
    I think I agree with Paul about the fact that no tread grooves let the surface wear a bit more evenly... and seem to last a bit longer.
    As for heating them up, it depends what compound you go with. I would think the average blue group rider could heat up a soft or med compound pretty easily at the track.
    Tony
    Trackdays in CT, NY, and NH
    www.TonysTrackDays.com
    Hiram, ME
    Lots of more knowledgable people have chimed in here, but I'll still add my $.02...
    Modern sport performance tire, just like modern SS bikes, typically perform beyond most riders capabilities. Unless you're racing or running fast blue group speeds, your money is probably better spent on a GOOD set of high performance street tires.
    Jericho, VT
    So we are REALLY talking just for the track?
    I see Degs point but I took the question as someone with a streetbike that wants to have longer lasting tires.
    I still say at a slower pacs a good DOT will last longer but I am BY FAR not the authority and bow out on this.
    Dic on
    Good point.
    That is the money question, right there.
    Probably at the 1:25 lap time mark you are warming the slicks up enough to benefit from them. But, you might not be smooth enough to not tear them up. That's probably the cusp, right there, 1:23 to 1:25 .
    derek
    OXX
    Dic on
    I still say at a slower pace a good DOT will last longer
    Absolutely correct.
    OXX
    Foxboro, MA
    kim get slicks, there's nothing more fun then feeling the back end slide a bit and still feeling in control!
    seriously though, i had a lot more fun on slicks at trackdays - but you'll want the 2nd set of rims or an option for tire changes....
    rode slicks in the rain for one session and it is scary and slow
    Denno - CCS|LRRS EX#49
    2006 Yamaha R6
    LRRS Rookie of the Year 2008
    i held off on getting slicks until i had the suspension to handle the extra grip.
    Jericho, VT
    I am holding off on getting slicks until I have the talent to use them... may never happen.
    KB KB's Avatar
    Manchester NH
    Quote Originally Posted by TESTINGurTOMATO View Post
    Isn't that an oxymoron. Oreo and school in the same sentence?
    That EX is going down this year in sportsman!!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    KB KB's Avatar
    Manchester NH
    Quote Originally Posted by kermita View Post
    My motard is plated and when jetting I usually slap a plate on and do a few highway runs, numbers, slicks, the whole nine. Turns some heads!!
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Quote Originally Posted by rmbbikes View Post
    Remind me to turn around & wave to you as I lead you up turn 4 again... it was beginning to turn into a tradition
  1. Move QUICK, almost NEW Pirelli Slicks F/S - $200!!!
    By scottieducati in forum Pit Area
    Last Post: 07-20-07, 08:52 AM
  2. Slicks
    By Rye in forum Pit Area
    Last Post: 03-19-06, 07:47 PM
  3. Replies: 0
    Last Post: 06-03-05, 08:26 PM
  4. Great deal on slicks
    By Kip in forum Pit Area
    Last Post: 05-07-03, 08:32 PM
