Results 1 to 5 of 5
2007 kawasaki ninja zx6r - running too hot reaching highest temp
    new to fourms but i also have a 2007 kawasaki ninja zx6r with heating problems when i stop at a light or just sitting there running even with fan on still runs hot reaching high temp and over flowing coolant
    i have changed the thermostat have had the fan wired to a switch so even when the fan is on it still runs hot please help!!!! any help or solutions ???
    the temp rises fast at a stop light jumping over 200 mark then jumps around untill it hits 244 then it just blinks HI i need to know what to do.........
    Derry NH
    Re: 2007 kawasaki ninja zx6r - running too hot reaching highest temp
    Bad water pump maybe?
    coolant not burped properly?
    Nov 2009
    Bristol County
    Especially after the thermostat swap.
    Bad pressure cap?
    nedirtriders.com
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    Why did you change the tstat? I assume it was overheating before you did that? Has the new thermostat made any difference better or worse or was it acting just like this before you changed it?
    First step as jim said is to make sure its burped properly and no air is in there anywhere.
    Also do a compression check just to be safe. IF your head gasket goes it can cause this even with out mixing fluids. If your compression is good then your gasket probably isn't causing it, move on.
    If your cap isn't holding pressure there will moste likely be chalky dried residue around it from coolant.
    Have you flushed out the system? If you have a bunch of crap sitting in your radiator blocking flow it can cause this.
    Take a look in your radiator thru the cap and make sure there is no visible junk in your pasages that you can see although I doubt it would get that bad at this age, but if there is then you should deffianately do a good flush on everything.
    May sound dumb but did you put the thermostat in corectly? If you clocked it wrong or put it in backwards it can block flow and cause over heating.
    Last but not least like Eric says if your waterpump is gone you will over heat.
  1. For Sale - Motorcycles | 2008 Kawasaki Ninja 250r - Currently not running
    By drowe531 in forum For Sale
    Last Post: 11-05-21, 09:00 PM
  2. For Sale - Motorcycles | FS: 2007 Kawasaki Ninja ZX6R - $3,000
    By virtualbong in forum For Sale
    Last Post: 09-14-16, 09:30 PM
  3. For Sale - Motorcycles | 2007 Kawasaki Ninja ZX6R - $3,850 - Burlington, MA
    Last Post: 09-14-16, 12:38 PM
  4. For Sale - Motorcycles | FS: Kawasaki Ninja ZX6R
    By kb1 in forum For Sale
    Last Post: 03-11-15, 02:07 PM
  5. For Sale - Motorcycles | 2005 Kawasaki Ninja ZX6R (636)
    By jmazz in forum For Sale
    Last Post: 07-31-14, 12:53 PM
