Results 1 to 19 of 19
5mm hex for drill?
    Lifer akira700's Avatar
    Apr 2005
    in the city
    5mm hex for drill?
    Recently I picked up a little cordless bit driver
    since my 18 Volt Dewalt drill is a bit of over kill
    bolts and screws on my bike.
    I'd like to be able to get a 5mm hex bit for it.
    But have not been able to find one. I can find
    american standard measurement hex sizes like
    3/16 etc but not metric.
    Anyone know where I can get this?
    Seems like a popular tool piece for those with
    metric bikes.
    Waterbury, VT
    5mm hex for drill?
    Dewalt has a driver kit that has adapters for 1/4 and 3/8 socket drives.
    SSearchVT
    Apr 2005
    in the city
    5mm hex for drill?
    Thanks but:
    I mean 5mm hex (male)
    Not 5mm socket (female)
    Lifer Pittenger5's Avatar
    Austin
    5mm hex for drill?
    Theres a place in Wakefield, Metric Supply House or something, they've had everything metric Ive ever needed for my bikes. MIght wanna give them a call and see if they have anything.
    Zip Tie Alley #505
    High maintenance priss
    Central MA
    5mm hex for drill?
    You want a 5mm hex that attaches via a 1/4" quick-change, correct? I did a quick google search and found that Ingersol Rand makes a number of 1/4" quick change bits, including the metric allen/hex that you're looking for. A good supply house should be able to get 'em. I have a metric set w/ 1/4" drive from Sears, but its not quickchange.
    See their ad, page 3.
    Linky
    Linky 2 Part # HXALK-9M
    Apr 2005
    in the city
    5mm hex for drill?
    Thanks Keena,
    Sears and Home Depot didnt have them.
    Using the part # from the pdf I found these guys:
    http://toolrage.com/prodView.asp?idproduct=5584
    http://www.toolbarn.com/product/ingersollrand/HXALK-9M/
    Sucks though that I need to by a large set when all I really need the
    the 5 milly. Oh well.
    Just Registered
    Is it not obvious?
    5mm hex for drill?
    Dude you spend 10$ total.
    Go to home depot and buy a 3/8" socket drive adapter.
    Then go walk over to the tools and buy a 5mm hex bit "socket" (even though a 3/8" drive with a 5mm hex bit sticking out of it).
    I can take pics if needed, but if you can't find the "socket" , just go to sears and tell the dude you want to drive a 5mm hex cap screw with a 3/8" ratchet. But first spend the 1.99$ on the 3/8" - quick drive adapter at HD.
    I have a dewalt 9.6v cordless screwdriver that I use this setup with and it's mint.
    www.gpsdiscussion.com
    motorcycleaddicts.org
    Just Registered
    Is it not obvious?
    5mm hex for drill?
    here's another hint - never use power tools to INSTALL fasteners you care about, only remove.
    Just Registered
    Is it not obvious?
    5mm hex for drill?
    Here I couldn't resist:
    3/8 adapter: (2$ at home depot)
    Amazon.com: DEWALT DW2542 3/8-Inch Socket Adapter: Home Improvement
    5mm hex "socket" (5.49$ at sears)
    Craftsman 42675 5mm Hex Bit Socket at Sears.com
    General Features:
    Drive Size 3/8 in. Socket Type Hex bit metric socket Socket Size 5mm
    Apr 2005
    in the city
    5mm hex for drill?
    Thanks for all the help folks.
    I'll be buying something soon.
    Waterbury, VT
    5mm hex for drill?
    +1 on using power/air tools to put stuff together (and take apart). Driving lag bolts into a deck, or taking off lug nuts is one thing - but I use hand tools for almost everything I do on cars and motorcycles. It takes longer, but you can feel what the bolt and parts are doing.
    As for hex drives - get sets of both straight cut, and ball end. The ball ends are great if you need to work at a little bit of an angle, the straights get the best contact patch on the heads.
    SSearchVT
    Central MA
    5mm hex for drill?
    Quote Originally Posted by somestrangeguy View Post
    General Features:
    That works too (I have these as well). The 3/8" adapter is great for any 3/8" drive socket. The 3/8" socket-mounted allen/hex bits are most useful when you need to use a torque wrench on an allen/hex fastener.
    Another thing you could do is get a quick-change 1/4" bit holder. ALso avail at HD/Lowes/etc... Obv. works w/ any non-quickchange 1/4" bit. Very handy piece. Come in various llengths too. Linky
    +1 on all the assembly comments and stuff. Power-tool remove. Hand-tighten (tool to torque if needed).
    Not 1-uping StrangeGuy's comments. All of these different tools are great and have their own strengths. I'd get one of each.
    LRRS EX #99 Kitt's Avatar
    Lake Champlain, VT
    5mm hex for drill?
    is this really a thread?
    Central MA
    5mm hex for drill?
    No, its not. Its been no help to the OP. Someone should delete this thread. Lets get back to posts about how many names we can come up with for poop.
    Lake Champlain, VT
    5mm hex for drill?
    ok, just checking
    Apr 2005
    in the city
    5mm hex for drill?
    Well thanks for bringing it back up to the top !
    Here's what I am going to do if anyone cares.
    Saw off the straight part of 5mm allen wrench
    and use that !
    Just Registered
    Is it not obvious?
    5mm hex for drill?
    Yeah, there really is no limit, you'll use them all someday
    I have a few drawers of random air tools, and a couple of cordless/electric impacts as well, but my favorite one for working on the bike is this DeWalt 7.2v Screwdriver. Mine is actually 9.6 I think, but it's got the right amount of snap to break the 'light stuff' loose, and snug it back up without much cause for concern (just click torque way loose and then take it to N tightness by hand).
    If you do get into the impact drivers, buy the Ryobi bits since none of the 1/4" drive stuff is rated for impact anyways (except $$$$ Hilti and Milwaukee) and they'll just get torn up anyways - the hardnes of the DeWalt bits actually seems to kill them faster.
    Just Registered
    Is it not obvious?
    5mm hex for drill?
    Quote Originally Posted by akira700 View Post
    and use that !
    We do, but we don't condone that sort of behavior.
    Spend the 10$, you think you're not going to lose that stub of a hex key the 2nd time you use it...you're lying to yourself
    Apr 2005
    in the city
    5mm hex for drill?
    Well like your sig says: Domo arigato !
    The driver I have is this little 4v Ryobi...
    http://www.ryobitools.com/powertools/tool/hp40lk1/
    Only $25 with about 20 bits, case and even a little LED on the front
    for working in low light, its a deal!
    Its super handy and I wouldnt worry about this baby
    stripping anything. Its just what I need for removing my
    plastic fairings.
  1. drill press
    By wookie in forum Pit Area
    Last Post: 05-05-08, 09:33 AM
  2. Best way to drill plastic?
    By hohum in forum General Bike Related
    Last Post: 10-04-04, 02:21 PM
  3. drill my windscreen
    Last Post: 08-20-04, 12:46 PM
