Results 1 to 10 of 10
Bike Electrical help
    Guys I got a first generation GSXR750.
    It won't fire and start. It was running then stopped firing when under starter motor so I swapped out a dodgy right handlebar control which contains the run button and starter ofcourse. that seemed to work.
    However 2 days later it is not firing up again.
    Its getting fuel
    Fuses are all good
    Spark is very dull, not a great deal of spark and even after swapping coils out with both spares and a set of accels, spark didn't change.
    It seems to be something related to either the kill switch not working or the bike isn't producing enought power to the coils. Any suggestions of what i could be looking for?
    Any suggestions or help greatly appreciated as I have the bike booked into a shop but its a 3 week wait.
    Sep 2007
    Hinsdale, nh
    Re: Bike Electrical help
    I'd start checking for a short in the wiring somewhere .It sounds like you must have just moved it around enough when you changed the handle bar control to make it run and now the shorted wire has settled back to where it was.
    Tip over sensor.
    Lifer ZX-12R's Avatar
    Candia, NH
    Check the wiring (12V and returns) for the coils. If any of them are partially shorted you will get a weak spark.
    Is the starter struggling? If it is, you may have a weak battery which can also give you a weak spark.
    Lifer BostonSVkid's Avatar
    Dec 2005
    Regulator/Rectifier draining the battery?
    2006 Ducati Monster S2R800
    Coils are getting 11.7 volts. I curennty have a new fully charged battery that i am also jumping from a car battery.
    I have no idea what a "Tip over Sensor" is or even whether then early models had one.
    BostonSVkid it has been mentioned to me about the regulator, I might try changing it today. What does the regulator do exactly? Regulate power throughout the entire bike?
    The bike is backfiring upon attempting starts big time. they are short very loud explosions throught the exhaust. sounds like a gun shot.
    Sep 2006
    Around the corner
    CAM CHAIN?
    BAD GROUND?
    SHORT IN THE WIRING?
    The rule is:
    Just checked the ground from the battery to the engine, cleaned the contact area. tightened it back up, pressed the start button and it initially turned over without starting but when dead and the bike is now dead and won't even turn over. Pressing the starter switch does nothing.
    Dec 2005
    I once had to clean my starter switch because my bike wasnt starting.
    As for the regulator/rectifier. It regulates the voltage in the bike. It is finned because excess electricity is converted to heat that is released into the fins that are cooled by air.
    I'm pretty sure the early gixxers never had one of those, I know the item you are talking about, seen them on many bikes but I certainly don't have one with fins at least on this or any of the other early gixxers i have.
    Update, the fuse blew and it is now back to turning over without firing
  1. Electrical Help: KTM
    By iTGbuDeeV in forum Dirty Bastards
    Last Post: 05-22-18, 07:24 PM
  2. Jimmy 2 Shots fixed my bike's Electrical Problem!?!?
    By FireboltEric_MA in forum General Bike Related
    Last Post: 07-17-11, 09:28 AM
  3. Need electrical help!
    By akira700 in forum Bike Maintenance
    Last Post: 04-09-09, 02:50 PM
  4. Need some bike help... electrical related
    By TTD in forum General Bike Related
    Last Post: 04-04-07, 03:44 PM
  5. Bike Related Question for the Engineering / Electrical Crowd....
    By Awesome in forum General Bike Related
    Last Post: 02-04-04, 01:29 PM
