Results 1 to 9 of 9
How long should bike run on battery alone?
    High maintenance priss
    Central MA
    OK, I'm trying to get this Suzuki GS of mine running. Charged the battery w/ a tender, started second try. Bike ran for 20 sec then died. Then 10 sec, then a couple seconds. Then wont start -> battery already dead.
    So I know the battery can't hold much of a charge. I figure I need to test the R/R and Generator to see which component is shot. I've got an Optima Yellow Top auto battery that I plan to use to keep the bike running so I can run a few electrical tests. How long should the bike run off of the battery alone?
    PS - I started this project by cleaning and rebuilding carbs (didn't separate the bank, just replaced all jets, needle valve, idle screws, set float height, etc...). There doesn't appear to be a fuel delivery issue (carbs leaked fuel...another story tho). Motor sounded good for the short time it did run. Figured it should keep running once started -> this is why I'm checking charging system.
    A bike should run for at least an hour on a good bike battery alone. That's under load.
    Central MA
    Cool, didn't know it would run for that long. I guess the current battery is really toast. It has a mfr. date of '06, so I'm guessing that this bike has been deep-discharging the battery for a while.
    Thanks.
    WoW Josephd14's Avatar
    Fitchburg, MA
    It will run till the Battery dies...
    <div style="width:160px;border:1px solid #036;padding:5px;text-align:center;"><a href="http://www.myyearbook.com/?me=AzUFa1czXWRWZgJnADkCPA==" target="_blank"><img src="http://assets.myyearbook.com/logo_blue_blog.gif" width="146" height="38" style="border-width:0px"></a><br><a href="http://www.myyearbook.com/?me=AzUFa1czXWRWZgJnADkCPA==" target="_blank" style="color:#036;font-family:Arial,Helvetica,sans-serif;font-size:15px;font-weight:bold;">Sign My Yearbook!</a></div
    Central MA
    My race f4i ran for 35 minutes at race pace. it had no charging system.
    Your reg/rec is fucked (in my humble opinion)
    Unplug the headlight if you want to get a little more life out of it.
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    It depends on how good your battery is, how much your reving. The more you spin the quicker it will die.
    www.bostonmoto.com
    Forum Rules
    Central MA
    Quote Originally Posted by Mad Max View Post
    Headlight has an on/off switch. Its an OLD GS.
    Quote Originally Posted by beet View Post
    Just idling & 5k for a short bit in order to test alternator output and R/R.
  1. Battery issue - bike won't start
    By NH848 in forum Bike Maintenance
    Last Post: 07-16-16, 06:22 AM
  2. Wanted - Other | Used car, boat or bike/ATV battery
    By nick5446 in forum Wanted
    Last Post: 06-02-16, 12:53 PM
  3. How long does a transponder battery last?
    By ThunderCycle in forum Pit Area
    Last Post: 02-01-12, 07:53 PM
  4. Pics of the bike after the "crash" on the big big long long ride....ride
    By imkindafkedup in forum General Bike Related
    Last Post: 02-05-08, 06:31 PM
  5. Big, Big, Big, Long, Long, Long Ride - Crash Update
    By johnnybob in forum Rides & Events
    Last Post: 09-06-07, 07:08 AM
