Results 1 to 25 of 48
Bike vibrates
    Jan 2009
    Waltham
    Wirelessly posted (Tilt: HTC-ST7377/1.59.502.3 (67150) Opera/9.50 (Windows NT 5.1; U; en))
    My bike vibrates mostly through the clipons, it might be the only place i feel it, not sure. It started doing this after my lowside at bomo.
    It vibrates when:
    In neutral moving from 2k rpms and up.
    In neutral not moving(sitting on kickstand) from 2k rpms and up.
    In any gear moving 2k rpms and up.
    In gear with clutch in moving and not moving 2K rpms and up
    It doesnt vibrate:
    While moving with the clutch in and no gas givin.
    When its off.
    I am going to change the oil and take the plastics off and check the motor mounts tomorrow. If you are unfamiliar with my lowside, it was when i was fully leaned over and wasnt much of a shock to the woodcraft slider, minimal damage occured to the bike/plastic, the right side clipon had rotated a little bit due to sliding on the ground. Bike is a 2k9 gixxer 750 with 13k miles on it.
    Any Ideas?
    Dec 2005
    Near The Dragon
    Re: Bike vibrates
    soft misfire?
    Get out while you can
    Find your own path
    Infected Slyder's Avatar
    Concord, NH
    Re: Bike vibrates
    You probably knocked something loose.
    My bike vibrates so bad in the clipons my throttle hand is asleep and useless after 20 minutes or so...unless I keep hitting the clutch and flexing my hand. When I hit slow bumps I can hear something making a noise and for the life of me, after having nearly stripped the damn bike...I can't find what's causing it.
    It very well could be a heat shield (piece of aluminum) on the side fairing...might want to check those. I should epoxy mine, highly doubtful I'll ever need to remove them from the plastic.
    Lifer Danz19899's Avatar
    Grafton, Ma
    Re: Bike vibrates
    lol i just had to switch to woodcraft clip-ons due to my high-side and damn those unweighted things vibrate a lot more then the old ones.
    As people said you prob knocked something loose, just take your fairings off check everything over. even a soft crash can jolt a lot of bolts loose. After my crash i found a lot of loose bolts
    www.bostonmoto.com
    Ride to live, live to ride
    Lifer Pittenger5's Avatar
    Austin
    Re: Bike vibrates
    Try shutting the bike off. That should solve the vibration.
    Zip Tie Alley #505
    Re: Bike vibrates
    If you want I can take it for a ride see if its normal or not compared to either of mine....U may just be hearing/feeling things LOLOLOLOL witch happens..
    I too lowsided in 11 in my 2nd race real light but no issues after....and to be honest they can take a lot more abuse than U think.....
    Uxbridge, MA
    Re: Bike vibrates
    Stop Low siding Please...
    Jan 2009
    Waltham
    Re: Bike vibrates
    Pigman I thought that too but I had Sheppo and a few of his mechanic friends check out out Tuesday at bike night, something is definitely not right.
    I did go over the bike today and there were a couple bolts that needed some torqueage. I am going to try changing my oil and blinker fluid and see if that helps sooth 'er down.
    Quote Originally Posted by FireboltEric_MA View Post
    Stop always passing me!
    Jan 2009
    Waltham
    Re: Bike vibrates
    I also wouldn't be opposed to anyone that wants to take it for a spin to see if they can come up with something.
    Re: Bike vibrates
    Quote Originally Posted by WordTooYoMamma View Post
    Yea......bring it by I will figure it out I am a GSXR GURU
    Jan 2009
    Waltham
    Re: Bike vibrates
    I have no idea where by is
    Re: Bike vibrates
    HAHAHAHAH YEAAAAAA.......I am located in Burlington
    Worcester, MA
    Re: Bike vibrates
    is it worse on one side? my first thought was a TB sync was in order, but then you mentioned the crash.
    LRRS EX #165 (formerly)
    Lifer DuncanMoto's Avatar
    Re: Bike vibrates
    Quote Originally Posted by Danz19899 View Post
    You do know that we have bar end weights specifically designed for the WoodCraft Clip-ons........
    Lifer slammp's Avatar
    Jul 2008
    Massachusetts
    Re: Bike vibrates
    Does it vibrate in the ten oclock wheelie position or only when both wheels are on the ground?
    Austin
    Re: Bike vibrates
    Quote Originally Posted by DuncanMoto View Post
    Only when his girlfriend is on it.
    Stop letting her have beans for dinner
    Zip Tie Alley #505
    Lifer R1's Avatar
    Somewhere you dont know...
    Re: Bike vibrates
    Quote Originally Posted by Slyder27 View Post
    My wifes GSXR 600 does the EXACT same thing...
    I stripped it down and put it back together and got nothing...
    I am baffled as to what it could be....
    Lifer Expat's Avatar
    Mar 2007
    Re: Bike vibrates
    It is obviously engine induced, I would take off all the bodywork and look for something loose or touching the frame that shouldn't be, exhaust maybe?
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Bike vibrates
    Quote Originally Posted by Expat View Post
    what exhaust... Actually that's not a bad idea with the can getting destroyed in the lowside it could have bent something soe it's touching slightly...
    It vibrates a lot. Hey Chris, maybe you can sell tickets like a carnival ride
    and have the wimmen line up at MCN...
    Posted by Jane in BoxChat
    In the words of R7 ..... you should throw it in a dumpster and buy a yamaha.
    Uxbridge, MA
    Re: Bike vibrates
    HAHA...You got yourself a deal bud!
    Grafton, Ma
    Re: Bike vibrates
    damn it Ted lol now i have to buy more shit from you
    www.bostonmoto.com
    Jan 2009
    Waltham
    Re: Bike vibrates
    Still having this problem. Case of beer to someone who want to diagnose a vibrating bike.
    I am positive every bolt that holds the engine in place is tight yet the footpegs and bars vibrate starting at around 4k in every gear. Enough to legitimately numb both feet and hands.
    Lifer wiggeywackyo's Avatar
    Feb 2009
    City
    Re: Bike vibrates
    Does the frequency of the vibration go up with the engine RPM? Where is it felt the most? Any noises? Can we put some girls on it?
    LRRS 878 Clapped out Gixxah
  1. Replies: 68
    Last Post: 08-17-18, 12:53 PM
  2. For Sale - Motorcycles | 2005 Suzuki GSX-R 600 - Track Bike or Race Bike (missing title)
    By Mchristiansen in forum For Sale
    Last Post: 07-20-18, 05:23 PM
  3. For Sale - Motorcycles | 2013 Kawasaki ZX6R Class winning race bike/track bike
    Last Post: 03-02-18, 09:38 AM
  4. For Sale - Motorcycles | 2004 Ducati 999 track bike/race bike (1036cc motor) $7999
    Last Post: 09-07-16, 09:43 AM
  5. Replies: 10
    Last Post: 02-11-09, 10:30 AM
