Results 1 to 11 of 11
Finding coolant leaks?
    Dec 2003
    Ma
    I have some sort of leak somewhere in my cooling system. only seems to spit out a bit while racing though. The res will never stay full, though i can't find any leaks in that or the hoses connected to it. All the hoses that i was able to check were full of liquid but after a race or ride I can always smell a little coolant, and usually have just enough in the belly pan to make it look a little wet or sometimes an extra couple drops. I've tried to run the bike and look for any leaks but I can't seem to find anything, i'm guessing it needs more pressure from the pump to squirt? Any tips on finding it?
    Super Moderator beet's Avatar
    May 2002
    Meriden CT
    pressure test it my boy
    dont try 100 psi it's verry easy
    www.bostonmoto.com
    Forum Rules
    May 2002
    Meriden CT
    Re: pressure test it my boy
    Originally posted by beet
    dont try 100 psi.. it's verry easy
    could be a weeping head gasket
    www.bostonmoto.com
    Forum Rules
    Re: Finding coolant leaks?
    Look harder? Maybe when you're sober?
    Dec 2003
    Ma
    Re: Re: Finding coolant leaks?
    you know me too damn well!
    Anyone have the kit to pressure test it and a compressor?
    May 2002
    Meriden CT
    Re: Re: Re: Finding coolant leaks?
    no compressor!!!!! hand pump is how you do it only like 20 psi
    your good for the hand pump
    www.bostonmoto.com
    Forum Rules
    Re: Re: Re: Re: Finding coolant leaks?
    Apparently, beet knows you well enough too!
    May 2002
    Meriden CT
    Talking Finding coolant leaks?
    Never met him but i could tell ......................
    www.bostonmoto.com
    Forum Rules
    Waterbury, VT
    If the pressure test doesn't show the leak you can also get a dye kit with a black light at the auto parts store. Good Luck...
    SSearchVT
    May 2002
    Meriden CT
    if you dont see a leak your in trouble .
    www.bostonmoto.com
    Forum Rules
    KB KB's Avatar
    Manchester NH
    Just ride it it's a honda they don't need coolant or oil
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. 2019 Husqvarna FE350 gasket leaks
    By Avak76 in forum General Bike Related
    Last Post: 11-02-20, 12:32 PM
  2. Fork seal leaks and seized bottom links ?
    By danny86 in forum Dirty Bastards
    Last Post: 05-07-11, 02:54 PM
  3. Help finding?
    By BigShel in forum General Bike Related
    Last Post: 07-05-09, 05:33 PM
  4. Help finding article?
    By capt1014 in forum Dirty Bastards
    Last Post: 08-21-07, 01:31 PM
