Results 1 to 22 of 22
Synthetic? Conventional?
    Braap Baggey22's Avatar
    Westford, VT
    So I bought a 2008 Kawasaki ZZR600 in July. The guy that I bought it from only put 579 miles on it. He did oil changes at 50, and 500 miles. I did an oil change at 1500 miles all with conventional oil. I'm now only about 300 miles away from my 3000 mile oil change.
    My question is should I switch over to synthetic? Stay conventional? Go semi-synthetic?
    Re: Synthetic? Conventional?
    This is one of the great internet worms of the 20th century, right up there with 9mm stopping power, Camaro versus Mustang and AKM versus M16.
    Personally, I use Rotella Synthetic because Paul Lawrence does.
    I started riding motorcycles at age 13. I bought my first car at age 31 - cages really don't hold a lot of interest for me. I've owned 28 motorcycles to date - 12 Suzukis, 8 Hondas, 3 Yamahas, and 4 Harleys. I've been about 545,000 miles on motorcycles. I've been in every one of the 48 lower states, on a motorcycle....I currently ride a Harley FLHRC Road King Classic and a Suzuki DL650 V-Strom.
    I own California Scientific, the world leader in Neural Network based artificial intelligence. I also make and sell aerodynamic accessories for motorcycles. I have a degree in engineering, and am currently doing post-graduate work in theoretical physics. dτ = √( Uμ gμνUν ) dt. You heard it here first.
    I publish these pages as a public service. I have no association with any of the other manufacturers or retailers listed....
    http://www.calsci.com/motorcycleinfo/index.html
    Just ride it rideitfast's Avatar
    Proctor VT
    I've been using nothing but Mobil One for over 30 years. Put a lot of miles on many a motorcycle and more than a few cars using it. Great stuff. Be prepared for a lot of different answers. One of the top debates among gear heads for decades.
    2010 Ducati 848 DARK
    2005 HD XL1200R
    1984 BMW R100cs
    1979 Triumph 750 Bonneville
    Don't be afraid of the dark side
    . dipthat's Avatar
    Boston, MA
    Go with hazelnut oil, more HP. Vroom Vroom
    2004 Yahama RX-Z
    2004 Yamaha 125-Z
    2008 Honda CBR 600RR, bitch is SOLD
    Castrol R30
    Banned Rambunctous's Avatar
    Waterville Valley, NH
    Use the same crap that you used at 1500 miles. It was good enough then wasn't it?
    I use Castrol 747 mixxed 25/1 with VP 110. Not good for your bike though.
    Lifer Stromper's Avatar
    Eastern Ct
    http://www.calsci.com/motorcycleinfo/Oils1.html
    He recommends commercial oils used in long haul Diesel trucks either dyno or synthetic. that is "C" grade
    I think a few years ago Mobil1 changed and is is not as good as it was 20 years ago but still very good
    Walmart has the rotella "C" grade oil and also Mobil 1 10-40 extended which is NOT energy saving so OK for bike.
    I am using rotella "C" grade for the remainder of the season and it is VERY NICE on the shifter test. moves like BUTTA $12 /gal
    What I do is
    Synthetic at beginning of season usually the MOBIL 1 motorcycle oil $9/qt.
    run up to 4000 miles normal for me
    End of season
    run bike hot then new filter and CHEAP dyno oil that just sits over the winter
    come spring
    drain cheap oil back to good synthetic.
    as its late in the season and I only will do another 1500 or so I am cheap and using dyno oil.
    I really believe that it doesn't matter 1 whit but we have to worry about some stuff.
    Jan 2007
    Rochester MA
    Motul conventional oil. Change it often (every 2 race weekends).
    Jan 2009
    Waltham
    Wirelessly posted (Tilt: HTC-ST7377/1.59.502.3 (67150) Opera/9.50 (Windows NT 5.1; U; en))
    extra virgin olive oil
    Use the search for anything involving but not limited to: oil,brakes,helmets,tires, jim being a pussy.
    that guy darkduc7's Avatar
    Apr 2010
    Georgia, VT
    ive used all kinds of crap, for the last couple bikes and snowmobiles, i've used mainly spectro full sythetic, its available locally at roadside.
    dyno will work fine, but i choose synthetic just cause it holds up to thermal breakdown better, and my duc runs quite hot. plus its my baby.
    honestly, anything will do as long as you change it frequently enough, and just make sure its not a high mileage oil with lots of additives in it since you have a wet clutch. i've heard of some synthetics screwing with clutches, but those cases seem pretty few and far between.
    CCS/LRRS EX #226
    LOW DOWN RACING
    Current stable:
    2008 hyper 1100
    2007 crf450r
    2009 yz450f
    2008 sikk mx 125 minimoto
    Old School Fool. ZX11D's Avatar
    Jan 2009
    Wilmington MA
    I prefer peanut oil. Tried canola oil but clutch started slipping.
    Lifer Danz19899's Avatar
    Grafton, Ma
    Amsoil i tried a bunch of different ones but this stuff is great.
    My bike's got 11000 miles and 6 track days feels as strong as the day i bought it and i just did 2 track days and my oil is still pretty clear.
    There's even a couple real scientific comparisons that I believe amsoil and mobil 1 came out on top.
    If this is Curtis hit me up i can get u a case of it pretty cheap
    www.bostonmoto.com
    Ride to live, live to ride
    Oct 2008
    Albany, ny
    Useing Extra Virgin olive oil is just silly, every one knows it has a low burning temp around 200 degrees.
    I use 50/50 bleach and antifreze. It has much less resistance then any other type of oil,synthetic or dino.
    It is a little corosive, so you need to rinse out the motor with viniger once in awhile, it will nuertalize the corosive Acidity.
    You will notice a huge seat of the pants feel for the power increse, which you might have to make other adjustments to you bike to compinsate for the extra torque and horse power. I had to change my sprockets so my wheel wouldn't spin so easy. And adjust my suspension
    I think the intranet might blow up this time whith the oil question
    Walmart-fullsyn diesel 5/20 $19/Gal=butter shift
    Beat It Like A Rented Mule !!
    Legend in my own mind
    Eastern Ct
    You need baking soda and lake water to neutralize blow by acid build up.
    Where did you go to HS anyway
    Yup, Paul Lawrence.
    Lifer DaveZX6r's Avatar
    NoChelmsford, Ma.
    That was a really good article. And I've been using rottellat since my third oil change. Its been great and its cheap but I also change every 3k no matter what.
    Eastern Ct
    I am very happy with how the bike is shifting now rotella dyno "C"
    amazing difference vs cheapo brake in oil
    Lifer NobodySpecific's Avatar
    Apr 2008
    Burlington, VT
    See? All you guys at bike night give me shit for running Rotella instead of moto specific oil. Jump on the band wagon Adam! Just do it!
    Just Registered Doc's Avatar
    Jericho, VT
    I have never had an issue with Rotella. Then again, my bike has a dry clutch.
    But I just buy whatever is cheapest.
    Ducatis (and many others) ship with full synthetic in them from the factory.
    Eastern Ct
    they get it for free
    KB KB's Avatar
    Manchester NH
    I use the oil that guys take out of their race bikes after each 3 race weekend. Free and clean.
    LRRS/CCS EX #13
    GMD COMPUTRACK
  1. Anybody using Full Synthetic Oil..
    By Murph in forum Bike Maintenance
    Last Post: 05-17-10, 05:00 AM
  2. Red Line Full Synthetic?
    By soloithtz in forum General Bike Related
    Last Post: 03-06-10, 12:23 PM
  3. Synthetic Oil? (Not What You Think)
    Last Post: 04-25-04, 11:52 PM
