So I screwed up (AGAIN). I was refurbishing my water pump and I needed to pull out my clutch to get at the chain to remove the pump. Well that worked and all is good with the pump. But the problem is I'm an ass and must have installed something wrong. I now cant get the clutch to disengage. Not just the cable is to loose, even when turned without the cable still no dice. It's an 02 fz1 with close to 30k but had no problems with the clutch prior. So what did I screw up?
