Page 5 of 6 FirstFirst 123456 LastLast
Results 101 to 125 of 147
Countershaft issue
  1. #101
    Old and Slow Sheppo's Avatar
    Westford, Ma
    Re: Countershaft issue
    Haha well its going to your place at some point anyway, maybe Ill just wait till you take a look at it.
    Posted by Jane in BoxChat
  2. #102
    I am Dead now
    Oct 2009
    The tax State of the Nation
    What's written here is, I don't know what you're talking about, but let me do some preaching anyways.
    Too much said.
    So sorry hessogood: It just seemed like there was going to be a kluge repair done. I just don't want to see someone due a bad repair just to get their bike on the road.
    In my 48 years of riding motorcycles I have seen too many accidents caused by failure to inspect all working components that are supposed to work correctly. Plus stupid rider errors, including my own couple of screw-ups! That caused me such pain that I live with each day, my back is toast from a 70 MPH get-off.
    And yes, I do know you, I have ridden with you before, & I think you are a great rider! it was about 4 years ago. PM Chuck (AKA 07bladerider) about me. Or PM me, I would be happy to talk with you again, we had fun on that night time run to the Blue Hills..... Too Damn dark!
  3. #103
    KB KB's Avatar
    Manchester NH
    Wasn't this bike already on the track with a setup that worked??
    LRRS/CCS EX #13
    GMD COMPUTRACK
  4. #104
    Lifer Pittenger5's Avatar
    Austin
    Yes, and we dont know what happened. Fortunatly, Tricky Mike came to the rescue
    Zip Tie Alley #505
  5. #105
    What was the final fix?
    Austin
    From the mouth of Tricky one. "Stainless bolt machined for a tight press fit into that hole. TIG welded, machined the filler away and chased the threads with a die. Ready to rock."
    Zip Tie Alley #505
  7. #107
    That sure is a purty shaft DB... : )
    Jun 2005
    Yeah, my thought was that it's not really under any load. It just needs to keep the sprocket from coming off. I machined a high-grade stainless bolt a couple thou over the ID of the hole, warmed the shaft up, froze the bolt and stuffed it home in an arbor press. It was stuck in there pretty good on it's own, so I didn't want to go crazy with the welder and screw the temper of the shaft, so I just zapped it in a couple places. Since I didn't have the sprocket/spacer I had to guess at what kind of length I'd need for the threads and I wanted the nut to be able to bottom out on the shaft if it had to. So, I put the shaft in the lathe (with a collet) and machined the weld filler away, then chased the threads that had been filled with filler. Came out OK. I really wouldn't crank down on the nut, but there's no need to. Not pictured is a matching stainless nut and wavy-type lockwasher that should keep everything in place. I little loctite probably wouldn't hurt either.
    Haverhill, MA
    Sweet job Mike!!!!
    Anyone tried to put the sprocket on the splines yet? Me having the uneducated question, if the couple of thousandths larger bolt being pressed into the hole caused any interference with the splines on the sprocket or not? Working with parts that a couple of thousandths makes all the difference recently at work got me wondering.
    Joel
    Jun 2005
    Sweet job Mike!!!!
    Joel
    Hmmm... That's an interesting question. I didn't mic it before and after. I wonder if the OD changed. I'd guess it didn't... or not much...
    The fit between the sprocket and the shaft is generally really loose (by machinist standards) so if it did move I'd be surprised if it would cause any issues.
    Austin
    Ehh, we'll just hammer the fucker on there. Then itll have even LESS of a chance of falling off.
    Zip Tie Alley #505
  12. #112
    Nov 2007
    Nice work tricky!
    Richie You should figure a way to safety wire the nut in place, maybe tricky could even add a little hole somewhere for you to do that
    Zip-Tie Alley Racing
    LRRS/CCS #103
  13. #113
    Haverhill, MA
    I'd be thinking the same way about the OD not changing much if at all. Just one of those stupid questions that pop into my head now and then.
    Austin
    Quote Originally Posted by ceo and a bunch of numbers View Post
    Nice work tricky!
    Ill figure something out.
    Zip Tie Alley #505
  15. #115
    live to ride seth399's Avatar
    Feb 2007
    CA
    Nice work tricky!
    As long as the sprocket itself has holes in it (speed holes!) then you can drill the bolt, and saftey wire it/loop through one of the holes in the sprocket and bam, you good to go.
    Nice work tricky!
    LRRS #399
    MX #505
  16. #116
    Nov 2007
    Quote Originally Posted by seth399 View Post
    Nice work tricky!
    I was thinking that but wasn't sure if the nut loosening would allow the sprocket to move.
    edit: nevermind it's splined so you could just do that, good call.
    LRRS/CCS #103
  17. #117
    Jun 2005
    Nah, it's a really good question. This may not be one of them, but there are situations where a tiny change would make a big difference. I'm going to ask some machinist buddies what they've found.
    Nice work tricky!
    Thanks, yo. I can put a hole in the nut fo-sho... You'd need a sprocket with holes, though. CS sprockets just laugh at drill bits.
    Feb 2007
    CA
    ya I forget if richies had holes...all mine do.
    LRRS #399
    MX #505
  19. #119
    Austin
    Yah, mine is full of holes. Nothing major to get sorted.
    Zip Tie Alley #505
  20. #120
    Lifer obsolete's Avatar
    Norf Sho
    Would the change in diameter go to the bolt or the shaft? I would imagine the force exerted but the bolt trying to expand would over power the force of the shaft trying to compress it, but I'm not an engineer so I'm curious. Could the shaft exert enough force to be compressing the bolt so the change in diameter would be transfered to the bolt being compressed as opposed to expanding the shaft.
    -Alex
  21. #121
    Feb 2007
    CA
    it really depends on how many thousandths over tricky went on the bolt...either way I'm sure he didn't go crazy and richie would be able to tap the sprocket on if there were any expansion.
    LRRS #399
    MX #505
  22. #122
    Haverhill, MA
    Geez, sorry guys, just a question that came to mind. I really hopeit isn't, and don''t think it will be, even close to an issue for Mike and Richie.
    Regardless, the work Mike did is bad ass and a solution to an otherwise troublesome problem Richie was having.
    Joel
    Feb 2007
    CA
    Joel
    now if tricky mike can just weld a pretty face onto richie...
    LRRS #399
    MX #505
  24. #124
    Austin
    Why? I have a girl, I dont care how ugly I am anymore.
    Zip Tie Alley #505
  25. #125
    Norf Sho
    Joel
    I don't want my post to be taken as I think it will be an issue. I'm just curious about how the physical forces whould opperate and what would change the reaction of the materials. I'm just a curious fella.
    -Alex
  1. my first issue..... Help!
    By P_easy in forum Bike Maintenance
    Last Post: 09-11-09, 08:00 AM
  2. countershaft sprocket seal leak
    By chief929 in forum Bike Maintenance
    Last Post: 04-28-08, 06:12 PM
  3. Love me some countershaft nuts.
    By JeffL in forum General Bike Related
    Last Post: 08-10-07, 10:38 AM
  4. front sprocket/countershaft question
    By trackdog in forum General Bike Related
    Last Post: 08-05-04, 09:28 PM
