Results 1 to 25 of 26
Ducati stalled and died
    GRRRRRRRRRRRRRR! capt1014's Avatar
    Apr 2006
    Ashburnham, MA
    So I took the girl out (2001 748) for the first time this year 2 Sunday's ago (lil damn)
    Drove approx. 3 miles to get gas...now problem
    OTWH from the gas station I got on it a little bit, snapped through a few gears. shortly after that about 500 yards down the road she started bogging down when I twisted the throttle. pulled over and she died. Started again immediately ran for 2-3 seconds then died and again. Did this 3-4 times every time I could hear the fuel pump prime, then she wouldn't start at all. Being EFI, I didn't trying to open the throttle at all when starting but there is the smell of gas, as though it had flooded.
    I tried to start it the other day and the same thing happens, fuel pump primes, turns over no problem, just won't fire. I've looked on line and have potential resolutions but wanted to get some other ideas of what it might be.
    Thanks Kirk
    As a side note, last year during the "cooler" mornings, there was a bogging or hesitation during acceleration, but it never died.
    http://www.facebook.com/#/profile.ph...&id=1185417660
    Live life now!....it has an expiration date!
    Friendship is like peeing in your pants,
    Everyone can see it,
    But only you can feel the true warmth.
    Re: Ducati stalled and died
    Sounds like your running the bowls dry under load............... time to pull the carbs
    Lifer FirstDuc-1098's Avatar
    Central Mass
    yea the carbs on these EFI motors can be a problem,
    probably some plugged venting
    Shit Corey says:
    My Bad..... Figured Ducati's didn't have FI Ever.... LOLOLOL
    thanks DAD
    You do realize your bike quit right in front of my Dad's house?
    Next time just wheel it up the driveway and say you know me. He woulda helped you get it running or at least get it home. He's a capable wrench who owns a Guzzi so he knows italian quirks. Hell, he coulda called me and I woulda been there in 2 minutes from work to assist.
    2016 BMW S1000XR
    I'd check fuel cap venting and other venting. It's starving for fuel from the sounds of it. Also check voltage, could be that it's making decent spark when cold, but not enough juice to do so once hot.
    2016 BMW S1000XR
    Lifer LuvDog's Avatar
    Ashland, MA
    Plugged fuel filter? What have the online tips pointed too?
    2003 ZX7R
    1995 916
    Apr 2006
    Ashburnham, MA
    Ya I did, but I just stopped there to adjust straps. Thank you, Iglu!
    Apr 2006
    Ashburnham, MA
    Online info points to a relay block under the seat on the right side that has a tendency to corrode and make faulty connection, not allowing the fuel pump to keep up with demand
    Nov 2009
    Bristol County
    Isn't the defacto standard to hold the throttle wide open on EFI bikes to shut off the fuel to clear out a flood?
    Sounds a lot like fuel starvation, and the venting makes sense. Wouldn't a sticky relay cause the pump to shut off, not operate at partial power? Or are you just on gravity-feed when it's off? Either way, when it doubt hit it with a hammer
    nedirtriders.com
    Lifer jasnmar's Avatar
    Mar 2012
    Chichester, NH
    Have you tried starting it withe the fuel cap open?
    I still think it's the carbs.
    Lifer Falko's Avatar
    MoonTown
    I bet they're missing altogether.
    Do you have a voltmeter? Read the voltage at your fuel pump when running and see if it is getting a full 12V.
    Walpole
    Get a couple guys to lift up the fuel cap and try running it to see if it is in fact a vent issue.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Mar 2012
    Chichester, NH
    You may need a front wheel drive car with snow tires to get the gas cap lifted.
    Lifer lrrs313's Avatar
    Asheville, NC
    But what oil should I run in said front wheel drive car? And what brand of snow tires?
    -Brian
    15 S-Works Venge
    Mar 2012
    Chichester, NH
    Amsoil or Royal Purple for oil.
    Brand of snow tires doesn't matter.
    They must have the official snow flake and be studded to get the gas cap lifted.
    Mar 2012
    Chichester, NH
    Sorry OP. The try with the gas cap open was serious. Otherwise ignore me.
    Douglas Ma
    Rotella! I run that shit in everything!
    Dec 2011
    Marlboro
    Quote Originally Posted by bstnsboy View Post
    Switching my blinker fluid to Rotella completely eliminated that annoying clicking sound!
    thanks DAD
    Ducati had Fuel Injection in 1988 dude. 10 years before you saw it on a Honda.
    CCS/LRRS #83
    Member Fitron's Avatar
    Mar 2016
    Winchendon, MA
    And Kawasaki had it 8 years before Ducati.
    Apr 2006
    Ashburnham, MA
    Go jack someone else's thread.
    Mar 2016
    Winchendon, MA
    I'd come over and take a look at it, but I work 3rd shift...I'm sure you don't! I'm sleeping when you're home from work. Maybe sometime this weekend we can take a crack at it?
    who knows
    i know nothing of Ducati's but i knew nothing of Honda's when I started out and I've figured out a few issues with my bike like this with some help.
    I'd def come by and give you a hand Kirk. holler at me.
  1. I almost died on the Kanc.
    By mojobreakfast in forum General Bike Related
    Last Post: 10-07-09, 10:47 AM
  2. friend died
    By SVRACER01 in forum General Bike Related
    Last Post: 08-31-05, 04:28 PM
  3. MY SV died
    By RandyO in forum Bike Maintenance
    Last Post: 12-27-01, 09:24 PM
