Results 1 to 20 of 20
Electrical - GBM or Bettencourts?
    Lifer akira700's Avatar
    Apr 2005
    in the city
    So I have sorta thrown in the towel on my
    diagnosing my electrical short. Could by my PC3 with
    mis-routed wiring (insulation worn through) or a shorted relay or switch (neutral?) or somewhere in between.
    I can make an appt at Greater Boston Motorsports or Bettencourts.
    Which would you recommend? Please say though if you have actual exp.
    with them, ok?
    2008 Honda CBR 600RR
    Lifer daviid's Avatar
    Oct 2004
    Plantsville, CT
    Re: Electrical - GBM or Bettencourts?
    if you think its your pc3, why dont you just remove it
    -Benjamin Franklin
    Lifer Pittenger5's Avatar
    Austin
    The red wire from a PC3 goes to the negative on the battery. Ask me how I know.
    Zip Tie Alley #505
    Mar 2004
    woonsocket ri
    How do you know?
    I was going to say the same thing as David. Just disconnect the PC and see if thats the problem.
    Providence,RI
    If you take it to GBM ask for Chris Tupta to work on it. He is a great tech. I know nothing about Bettencourts.
    Mike Green
    LRRS #450 novice
    http://www.mikegreensculpture.com
    '06 svx550
    '04 cr500 af le
    '04 525 smr
    '02 660 sms
    '01 drz 450 sm streetbike
    '99 r7
    '99 sv650
    '86 rg500
    Apr 2005
    in the city
    thanks for suggestions.
    I'd take out the PC3 if I knew with some degree of certainty
    that it's be worth the effort. See with with my having to take care of my
    daughter alot I don't have as much free time to pick at this issue
    as much as I'd like to.
    Prior to this last year I had the ignition switch over heat and
    the solder melted and it stopped the headlights from working.
    So its not certain that the PC3 is the issue. I just see that it was
    installed with the wiring routed oddly (not by me) after my rear
    end accident. It works (or did before this short appeared)
    RG, Has Chris Tupta done electrical work for you?
    Or is just someone you know.
    Providence,RI
    Both.
    He is a good friend of mine, but also a great mechanic that has worked on a bunch of my bikes, mostly when I have gotten in over my head, and troubleshooting. Which is usually electrical issues.
    Mike Green
    LRRS #450 novice
    '06 svx550
    '04 cr500 af le
    '04 525 smr
    '02 660 sms
    '99 r7
    '99 sv650
    '86 rg500
    Senior Member ahtune69's Avatar
    Jun 2005
    Needham
    +2 chris knows his shit, I work on my own bikes but when I have a question or stuck with a problem he's the guy I look for.
    Mike
    05 636
    Green Machine
    07 Husky sm510
    Mar 2004
    woonsocket ri
    Quote Originally Posted by akira700 View Post
    that it's be worth the effort. ...............
    You should only have to disconnect the wiring harness from the PC then connect the bike harness back together. You don't have to remove the whole thing. Just for a quick check to see if that may be the problem.
    i had an issue with bettencourts service. my clutch cable snapped on me on my way home from leaving bettencourts. i actually had a new cable at home, and just didnt get to installing it yet. since i was stranded and needed to get home, i had a friend bring me the cable & i got the bike back to bettencourts.
    the service guy was so rude to me. he made me feel like i was inconveniencing him, and he didn't want to bother replacing my cable. i was charged more for labor than the i was quoted, and he rushed me right out the door. i will never go to them again for service, but i do like their parts department a lot.
    Mar 2004
    Lynn, MA
    I also know Chris Tupta at GBM. Rachael the service manager is super nice and also knows her shit. I think they could also pick it up from your house too, if the bike is not running....
    Nov 2004
    Boston, MA
    Try Degsy if he is willing to get his hands into it....
    EVERYTHING is a repost
    06 749R #0047
    08 R 1200 GSA
    13 Monster EVO 1100
    So you've put too much current through some wires and melted the solder/insulation off them? How did this happen?
    There's a good chance you'll need to remove the cover from the whole wiring harness to see if you have a wire or three shorted together in the middle of the harness.
    But the first step is to just disconnect the PC3.
    Akira, it's fixed.
    Bad ground in the blue multi-wire connector to the headlight relay (and probably an iffy relay now also). Looks like water got into the connector. That rubberised plastic shroud over it needs to be kept in place and the connector kept out of the elements if possible.
    Anyway, all working now. I'll re-assemble the front end tomorrow (some strange epoxy/tape/plastic shims in the headlight area huh? LOL
    Apr 2005
    in the city
    Akira, it's fixed.
    Degs you rock! PM me the bill! And I'll be over as soon as I can.
    Yeah about the front cowling its not the most solid piece of body work ! No zip ties holding it together though!
    One of the screw anchors is about to fall right off. Need some ABS welding action on it.
    Southern, NH
    Akira, it's fixed.
    This is why I love this forum.
    Great community and people ALWAYS willing to lend a hand.
    I will get it all back together for this afternoon. I will check with Bettencourt's to see if they have a headlight relay as I'm not confident it will stay working now it has been arcing. Also, I will epoxy that screw anchor so it will need to dry for a few hours.
    Pick up tonight? I'll PM you.
    Apr 2005
    in the city
    Man Degs, if you were a foxy woman I'd kiss you!
    But your not so I wont !
    I'd bet the relay is an item to order, not in stock.
    Can't get it tonight.
    Maybe not till Sat. unless you can do it late on Friday like after 10pm?
    Let's arrange pickup for this weekend. I'm probably teaching MSF (not 100% sure yet) so evening would be better.
  1. Electrical Help: KTM
    By iTGbuDeeV in forum Dirty Bastards
    Last Post: 05-22-18, 07:24 PM
  2. Bettencourts or Brockton Cycle Center
    By Mike02048 in forum General Bike Related
    Last Post: 10-22-09, 08:14 AM
  3. Bettencourts Honda in West Bridgewater, MA
    By The Snowman in forum Business & Product Reviews
    Last Post: 08-27-09, 03:46 PM
  4. Bettencourts Bike show
    By Billy in forum Rides & Events
    Last Post: 02-16-06, 10:08 PM
  5. Replies: 1
    Last Post: 05-20-03, 01:57 PM
