Results 1 to 9 of 9
F4i Clutch
    Just Registered
    Mar 2003
    Shrewsbury, MA
    F4i Clutch
    Sunday did an oil change with my buddy Mark. Mobil 1 15w50. took a test spin and everythings great, runs like a champ.
    Monday i washed her up good, but started raining so i didn't do go for a ride, brought her back in the garage...
    tonight (tuesday) i decided to go for a ride and as a soon as i pulled out of the driveway i could feel something was wrong...the clutch lever was not fully disengaging..Any ideas? i loosened the bolt holding the lever into the housing and all that did was give me a loose lever...so i am thinking my line needs to be cleaned and lubed?? yes/no???
    Here is how the lever looks when released. this is as far as it goes..i can push it back with my hand, but it should completely release when i let go of the lever...
    Walpole
    F4i Clutch
    You want a small gap there. It gives just enough play to let the clutch engage without being held back. If you feel the clutch slipping at all then you may need a new one.
    You should keep that cable well lubed as well, it can corrode where you dont see it.
    2018 Harley Road Glide
    2000 Ducati 900ss
    2003 Harley Softail Deuce
    Waterbury, VT
    F4i Clutch
    A good rule of thumb for the gap at the clutch lever is about the width of a dime. If it slips at all with slack in the cable the clutch needs to be replaced or at least taken apart and examined. If it sticks even with no slack in the cable (for testing only) then either the plates are stuck together (which will usually come apart with a little riding, this is more common with bikes that have been in storage for a while), or the basket fingers have dings in them (usually from hard riding, used to be fairly common in MX bikes). Good Luck...
    SSearchVT
    F4i Clutch
    Did you use a pressure washer? if you did you might have washed away all the grease from the lever end and any cable lube from that end of the cable. The water has had time to get down in there and mix with the lube, making the lever feel stiff.
    derek
    Just Registered
    Mar 2003
    Shrewsbury, MA
    F4i Clutch
    Thanks Derek..i did not use a pressure washer but i did dry it off with a leaf blower...i bet that messed with the grease and lube. How involved is it to regrease the lever and lube the cable?
    I like them naked craig's Avatar
    May 2003
    Natick, MA
    F4i Clutch
    http://www.themcdonalds.net/richard/...tchcable.shtml
    hope that helps! I need to get one of those tools...
    May 2003
    Lakes Region, NH
    F4i Clutch
    that's a well done page. I am a visual learner so I think that it helps to have those pics along with it - then I can see what I shoudl be doing as opposed to guessing.
    Bras cause cancer.
    Just Registered
    Mar 2003
    Shrewsbury, MA
    F4i Clutch
    That's an awesome link..Thanks...
    i ended up adjusting it last night and now everything is fine...Thanks for your help evyone!
    May 2003
    Lakes Region, NH
    F4i Clutch
    what did you end up doing to get it working properly?
    Bras cause cancer.
  1. Clutch spring...lessen clutch pull
    By black in forum General Bike Related
    Last Post: 06-29-20, 10:25 AM
  2. Clutch
    By flippedr6 in forum Dirty Bastards
    Last Post: 12-28-18, 11:49 AM
  3. Wanted - Parts & Tools | Clutch perch bolt for 03+ SV650 (or complete perch) also 00-03 GSXR clutch perch
    By juha_teuvonnen in forum Wanted
    Last Post: 05-22-18, 10:57 AM
  4. For Sale - Parts & Tools | Yoyodyne slipper clutch, Ducati 848 wet clutch
    By jwm2k3 in forum For Sale
    Last Post: 04-27-17, 10:07 AM
  5. 848 Dry clutch mod
    By obsolete in forum General Bike Related
    Last Post: 07-15-11, 02:13 PM
