93 Kawasaki KDX 250 dirt bike with an inverted fork...just replaced the oil seals on the front fork, I followed the instructions well and everything seamed to be good until I was riding it today.
I used the proper adjusting tool to set the fluid level, made sure the air was purged out. I was able to drive the seals into place and put the retainer ring in place before putting the dust seal on. All the fluid stayed in and the fork seamed to function properly.
Then I was riding for about half an hour or so, nothing crazy, hit some jumps but nothing huge, then I stopped a little later and noticed the dust seal was near the bottom of the fork, the retainer ring was half popped out and the seal was half out and fluid was seeping through.
Any thoughts? I have a few...
Didn't touch the compression damping adjustment screw, but maybe I need to change the setting?
When I put the oil in and purged the shock, maybe I went to high with the outer tube and it took more oil than I thought?
Maybe I need to adjust the air pressure screw on top?
Any help would be greatly appreciated. Sorry for such a long post, just trying to give all the facts. Thanks.
