I think I may have bad fuel?
We were going to take the dual sports out for a ride yesterday. I couldn't get either of them to start I figured it was due to the cold.
I put heaters near the bikes to warm them a bit
leahs is still new, only 113 miles on it.
mine I charged up the battery and changed the spark plug.
I draind the float bowls on both figuring it might help if there was any crap in there.
Hers would finally start but would only stay running with the choke on. Even after the motor was warm.
Mine will only fire up with a shot of starting fluid but then dies out.
We pulled both of them into the house last night to warm them up for today.
This morning I pull them out, mine still won't fire up.
Leah's will start and run but only with the idle set up around 2000rpm.
I ended up parking mine and taking the v strom out instead.
Leahs bike will run but then when we get to the end of the road it idles down and dies, will only fire back up with the choke out then choke in and it runs fine for a while. But everytime we stop it dies again.
we ran almost a full tank through it today with some carb cleaner. Then topped it off with fresh gas from the pump. It wouldn't fire up again with out the choke out.
Anyone have any ideas?
I think my carb might need a good cleaning as the bike is 7 yrs old but leahs is brand new only 113 miles on it the reason I think its the gas is that both bike were filled from the same can in the garage as was my mini that was stalling on the ice a couple weeks ago.
