Results 26 to 50 of 74
Garage Heat
    Lifer Falko's Avatar
    MoonTown
    Re: Garage Heat
    How high are the ceilings? If they 9' or better and you are working mainly in a single area, I'd recommend something like this, http://www.morelectricheating.com/de...FYl9OgodEHYASA
    It will heat you and the stuff you are working on versus heating the air (which rises) which in turn heats you. We recommend IR heaters all the time as energy measures. And the one I linked is electric, you CAN get gas, but the installation is more. Installing them overhead makes them more convenient to work around.
    Lifer obsolete's Avatar
    Norf Sho
    Re: Garage Heat
    Quote Originally Posted by pontifex View Post
    What do you guys recommend for heating a detached single car garage so I can work out there on days like this?
    These are what caught my eye at HD. Prices seem right.
    Attachment 36947
    http://www.homedepot.com/p/Dyna-Glo-...specifications
    Attachment 36948
    http://www.homedepot.com/p/Dyna-Glo-...N#.UpIaDcReZ8F
    I have the first type. I have an uninsulated 2 bay 2 story gambrel attached garage with second floor. It heats up very fast but gets too hot real quick. So I do the on off on off. But it's worth it till I get a gas wall unit.
    Both need LOTS of ventilation too FYI.
    Ummm, nope. I have everything closed and keep a CO detector with display on. It's never read over 0, except when an engine is run for a bit.
    -Alex
    Lifer Billy's Avatar
    Feb 2006
    Metro West, MA
    Re: Garage Heat
    Interesting topic since I have a similar issue but not as bad. I have an attached garage which stays somewhat warm. What I mean by that is if its 0 degrees out, the inside of the garage will be in the high 30's usually around 38 mark. I've been looking for something to heat the garage to make it a little extra comfortable when working down there in the middle of the winter. Basically it needs to heat the equivelent of a 2 car garage area. Looking like electric is the way to go since it's enclosed and dont have a way to vent unless I open the garage door which I don't want to do.
    Windham NH
    Re: Garage Heat
    Bumping this, what did the OP go with? I'm looking for something to use with little ventilation.
    Re: Garage Heat
    I've had the propane tank mounted setup shown below for ~10 years. Heated many sheds and single car garages with it and worked many hours next to it with zero trips to the hospital.
    Thing can burn for 7hrs or longer on a full tank depending on how many burners I'm running and whether or not I'm on low, med or high.
    Back when I was renting a duplex, the power was out for 6 days during an ice storm. I would help the landlord by heating the basement so the pipes wouldn't freeze then I would help myself by heating my half of the duplex.
    It's a bad ass little set up, IMO.
    Two Burner Propane Heater, 10,000 to 30,000 BTU (F242650) at Aubuchon Hardware
    Garage Heat-6264501-jpg
    Re: Garage Heat
    look on craigslist for a mobile home heating unit and just stick that out there.
    Aug 2013
    New Bedford MA
    Re: Garage Heat
    I picked this up from Lowes last year and have been very happy with it
    Shop ProCom 110,000-BTU Portable Kerosene Heater at Lowes.com
    KNEE DRAGGING BAGGER sedanman's Avatar
    Oct 2014
    Pawling NY
    Re: Garage Heat
    A friend of mine went with the used oil fired forced hot air mobile home furnace plan. He mounted the unit outside of his shed and fed it with a 55 gallon drum. Probably not tha fanciest set up and may not (MOST LIKELY NOT) up to code but it was dirt cheap and worked flawlessly.
    Re: Garage Heat
    Not quite same application as OP but I had a Modine Hot Dawg heater installed by our furnace guy. It runs off the furnace heat so no external source is required other than the plumbing. Have it set to 40 degrees, if I want to work there I'll crank it up.
    Aug 2009
    Hillsborough County, NH
    Re: Garage Heat
    I sell both brands at my work. Schwank offers infrared heating available in gas or electric. Reznor offers an equal to the Modine Hot dog unit heater. PM me if you are interested.
    Schwank Infrared Heaters - Tube Heaters, Patio Heaters, Garage Heaters
    Products - Unit Heaters - UDAP | Reznor
    🇯🇵 2001 Honda CBR 929RR R.I.P
    🇯🇵 2009 Honda CRF 250X
    🇯🇵 2013 Kawasaki Ninja ZX636R
    🇦🇹 2016 KTM 1190 Adventure-S
    Lifer Rosco61's Avatar
    Oct 2007
    Peabody Ma
    Re: Garage Heat
    I have a 60.000 BTU hot dawg. 100 lbs propane tank next to the garage.
    Works great. Spend a bit extra.It's almost always worth it.
    Re: Garage Heat
    Quote Originally Posted by Rosco61 View Post
    i know its true with hookers
    Re: Garage Heat
    Plan is to put a small woodstove in my garage. Just bring coals up from the stove in the basement to the garage...instant fire. Boom.
    Windham NH
    Re: Garage Heat
    Has anyone used one of the IR heaters? I am planning to work out in the garage over the winter, might be nice to warm the equipment and not just the air.
    Oct 2014
    Pawling NY
    Re: Garage Heat
    Any heat source with a flame inside a garage where there could be gasoline vapors is a bad idea. You might get away with it for years but the possibility of blowing the garage to kindom come is always there.
    Re: Garage Heat
    Quote Originally Posted by sedanman View Post
    How would this be possible with the draft of a woodstove?
    Re: Garage Heat
    so propane is no no as well ? electric is the only thing that is safe
    woodstove is not an open campfire, flames are enclosed in a woodstove same as they are in an oil fired furnace, just a different fuel
    Oct 2014
    Pawling NY
    Re: Garage Heat
    Any fuel burning heat source meeds air to support combustion. A wood stove creates a significant significant draft . Gasoline vapors are heavier than air and settle on the floor. Open thw door of a woodstove to add fuel and the draft draws a large volume of air into the stove. If enough vapors are present ........ not good. There are stoves that have the ability to draw air in from a duct to the outside, this is usually done for thermal efficiency and still does not do away with the risk from refueling the stove. In thw case of my friend who used the mobile hpme furnace, only the supply and return air was ducted to the shed. Combustion air comes from outside. My own garage is heated with a hot water unit heater. I'm not a heating expert and I'm not telling you you can't get away with a woodstove in a garage. I'm just pointing out the risk. Call your insurance company and ask them what an acceptable heat source is for a garage. I guarantee they dont say woodstove.
    Oct 2014
    Pawling NY
    Re: Garage Heat
    Sent from my phone. Please excuse the typos.
    Re: Garage Heat
    If insurance says no ill just bring the bikes into the basement.
    Oct 2014
    Pawling NY
    Re: Garage Heat
    They probably won't like that either. Lol. That being said, my wife's FZ6 will be spending the winter behind the couch.
    Aug 2009
    Re: Garage Heat
    Not necessarily, seperated combustion can be utilized in a garage application. Combustion air is pulled from the outside and exhaust is vented directly out of the building.
  23. #48
    Oct 2014
    Pawling NY
    Re: Garage Heat
    Quote Originally Posted by Trajiks9 View Post
    Point taken.
    Re: Garage Heat
    How do you do that? Ductwork and a drier type vent to the outside and a wider sealed vent to the intake?
    Re: Garage Heat
    I'd be careful posting how the bikes will be stored. Doesn't take much for an insurance company to get all uppity about certain things such as bikes inside the dwelling.....something which I have always found amusing since their view is that 10g of gas is a no-no but 300g of heating oil is perfectly fine.
    Just my .02
  1. How can I heat the garage?
    By ftrain in forum General Bike Related
    Last Post: 11-17-07, 11:55 AM
