Hmm...not saying I've resigned myself to spending $250....but in looking into the Milaukee....you'd expect the only difference between these two models (2763-22 and 2762-22) to be the pin detent vs. friction ring, but the pin detent one has 350 ft-lbs (mode 1), 600 ft-lbs (mode 2) and 1,100 ft-lbs of nut-busting, the friction ring model has 100/700/no "nut busting" torque listed.
I suppose it doesn't matter for my purposes, since I'll be using it to take off but not put-on, 700 or 600 ft/lbs should be plenty either way, and definitely 1,100 of nut-busting torque should crush anything.
