Results 1 to 23 of 23
How to inflate your tires with WD40
    Member Cambridge K's Avatar
    Cambridge,Ma
    Two things help getting older - BMW'S and Metamucil
    Mar 2004
    woonsocket ri
    Re: How to inflate your tires with WD40
    You use ether not WD40. And it doesnt inflate the tire. It just seats it on the rim.
    Quote Originally Posted by dhuze View Post
    original formula wd40 was flamable, but it hasn't been flamable for 20+ years
    Ense petit placidam sandman's Avatar
    sema
    unless they changed the formula in the past 6 months. for the past 20+ years it HAS been very flamable.
    starting fluid works even better on a truck tire, but i must admit iv'e never tried it on a mc tire.
    jim
    "Molon labe"
    Quote Originally Posted by sandman View Post
    it burns, but does not create explosive fumes like ether, the aerosol propelent used to be flamable as well many years ago, it no longer works good as fuel for potato guns
    Harlingen, Texas
    The Material Data Safety Sheet (MSDS) from the manufacturer lists the flash point as 131 degrees F. That would make it flammable!
    http://www.wd40.com/files/pdf/msds-wd494716385.pdf
    Cambridge,Ma
    Fire lube
    Lifer richw's Avatar
    Aug 2004
    Baltic,CT
    beans candle then wait
    I use starting fluid myself
    Glen Beck is John the Baptist
    Quote Originally Posted by caddydaddy View Post
    like I said, it burns, it won't ignite from a spark at room temp, unlike ether that has a flash point of about 50 below zero
    years ago, the propelant that WD40 used in it's aerosol product had a low flash point and it could be used as potatoe gun fuel, not anymore
    Derry NH
    Brake clean/carb clean/starter fluid works better. Hell even hairspray in pinch would do.
    Junior Member screamingbuick's Avatar
    South Hadley, MA.
    I wouldn't use either, right down the street from my house a guy was using ether on a truck tire and static ignited it, the rim took his head right off and proceeded thru the shop roof...i wasn't there but i bet it wasn't a pretty site.
    Quote Originally Posted by screamingbuick View Post
    same thing happened to a mechanic in my home town. though he didn't lose his head, he almost lost his leg and 90% of the hearing in is left ear.
    call me a wuss but ether is explosive and I won't be mounting a tire that way.
    Senior Member Pestilence's Avatar
    Salem MA - Soon.. Sandy Eggo CA!!!
    If you've ever gone off-roading in BFE and popped a bead, you better have a can of starter fluid and lighter in the glove box or you're in for a shitty afternoon.
    Just remember to remove the valve stem or the tire will implode back in on it self.
    -John
    "It's more fun to ride a slow bike fast,.. than to ride a fast bike slow."
    07 Husky SM510R
    Littleton, Ma
    There is no way this happened.
    Just Registered Doc's Avatar
    Jericho, VT
    No. The flash point is the lowest point at which a liquid can become ignitable. Thus making it inflamable.
    131 degrees is not as inflamable as gasoline which flash point is something like -30 degrees.
    Edit:
    Sorry... Randy got it.
    Harlingen, Texas
    Edit:
    No, the flash point is the temperature when the vapors can maintain a flame. The first three words of the "hazards identification" section of the MSDS I provided say "DANGER! Flammable aerosol."
    Just because it won't explode like ether or gasoline doesn't mean it won't flame up with a match!
    Lifer obsolete's Avatar
    Norf Sho
    No flash point means it can ignite but may or may not be able to maintain a flame. That's why it is the "flash" point, because you can get a flash of flame but no burn.
    -Alex
    Norf Sho
    For the record: Inflammable = flammable
    Also I believe the limit for flash point for flammable liquids is 100F, anything above would be combustable to another temp which would determine non-combustable.
    -Alex
    Aug 2004
    Baltic,CT
    Large truck tires have bead rings that are worked on after the tire
    These can and do come off with great violence
    Old milk can
    Calcium Carbide
    good times good times
    May 2007
    Southern NH
    Quote Originally Posted by richw View Post
    Old milk can
    Calcium Carbide
    Newer truck don't have the rings anymore. I used to change those and we always used a cage when inflating...
    Muhammad Ali.
    KB KB's Avatar
    Manchester NH
    I love a nice ether explosion, and a nice ether binge.
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Lifer JettaJayGLS's Avatar
    Tahoe City
    Did this with ether to mount 225s on a 10inch wheel back in the day on my jetta....actually really easy to do.
  1. For Sale - Other | Free vintage truck tires - 7.00x15 - Decent yard tires (not roadworthy, IMO)
    Last Post: 06-03-14, 11:29 AM
  2. I need some tires!
    By lopycam in forum Pit Area
    Last Post: 03-28-11, 11:55 AM
  3. Tires, Tires, Tires...
    Last Post: 06-06-07, 10:24 AM
  4. where to buy tires.....
    By jesse_k in forum General Bike Related
    Last Post: 06-20-05, 09:49 AM
  5. tires tires tires free tires
    Last Post: 12-16-03, 10:10 PM
