Two things help getting older - BMW'S and Metamucil
You use ether not WD40. And it doesnt inflate the tire. It just seats it on the rim.
The Material Data Safety Sheet (MSDS) from the manufacturer lists the flash point as 131 degrees F. That would make it flammable!
http://www.wd40.com/files/pdf/msds-wd494716385.pdf
Fire lube
beans candle then wait
I use starting fluid myself
Glen Beck is John the Baptist
Brake clean/carb clean/starter fluid works better. Hell even hairspray in pinch would do.
I wouldn't use either, right down the street from my house a guy was using ether on a truck tire and static ignited it, the rim took his head right off and proceeded thru the shop roof...i wasn't there but i bet it wasn't a pretty site.
If you've ever gone off-roading in BFE and popped a bead, you better have a can of starter fluid and lighter in the glove box or you're in for a shitty afternoon.
Just remember to remove the valve stem or the tire will implode back in on it self.
-John
"It's more fun to ride a slow bike fast,.. than to ride a fast bike slow."
07 Husky SM510R
No, the flash point is the temperature when the vapors can maintain a flame. The first three words of the "hazards identification" section of the MSDS I provided say "DANGER! Flammable aerosol."
Just because it won't explode like ether or gasoline doesn't mean it won't flame up with a match!
For the record: Inflammable = flammable
Also I believe the limit for flash point for flammable liquids is 100F, anything above would be combustable to another temp which would determine non-combustable.
-Alex
Large truck tires have bead rings that are worked on after the tire
These can and do come off with great violence
Old milk can
Calcium Carbide
good times good times
I love a nice ether explosion, and a nice ether binge.
Did this with ether to mount 225s on a 10inch wheel back in the day on my jetta....actually really easy to do.
