ok guys here to pick your brains. When i start accellerating i hear and feel a klunk that feels like it is coming from below me, can't tell if it is front, rear or directly below, it almost seems to move. I just had both tires changed, tightened the chain then had to tighten it again after 3 days, seems to be holding tight for now. seems louder if i am starting and accellerating around a corner. Sprockets look mint even though they have 18k miles on them and the chain looks alright but might it not be? the front sprocket actually look sbrand new, shiny and everything and all teeth are perfectly shaped and all there, rear is dirty (chain wax for 18k miles) but shape and none missing. I am out of ideas, what should i check next?
cush drive? Correct spacers?
when i tightened it the first time i left about 1/2 inch and 1/2 inch down for play but after 4 days it was all sloppy again so i tightened it more this time. 1/8th or so just to see if it would loosen again and it is holding tight, i am going to loosen it again a bit after work. the chain has 18k miles on it but looks alright, it dosen;t skip over the sprockets (as far as i can tell). would it clunk if the chain is worn?
you want an inch and a quarter of play.
as far as cush drive, Keith just did the tires and we didn;t take the rear sprocket off and he said something about thati'm not sure what a cush drive is, he would be better to ask
if the sprocket didn't come out it's still in there.
fair enough, and the clunk happens when there is tons of slop in the chain and when it is too tight, i will loosen it again when i get home but it did it when there was way more than even 1 1/4 of play
I had what sounds like something similar. It sounded like skipping just after the clutch engaged. Happened mostly when the bike was under load, like when starting from a stop on a hill.
Turned out to be that the chain was too tight. (according to Peter at G.M.D. Computrack Boston)
Thanks, i'll loosen it and se4e if it helps, btu it seems the same whether loose or tight. And i know it is realy bad to overtighten, i thought of that after i did it, thats why i am going home to loosen it. guess it is time for a new chain from the sounds of it though. Maybe i'll re-gear and lose some of that gas mileage i am so happy about
If the clunk only happens when the chain is very loose, it's likely slapping the underside of your swingarm under acceleration.
nope, tight too....dosen't seem to matter
Is your axle slipping and slamming forward because you are not torquing it enough to hold it in place? Or is the chain gaining slack without any movement of the axle moving forward? There should be no space between the axle carrier and the stops(adjusters) when you torque the axle bolt. You are using a torque wrench right?![]()
check your brakes, make sure all your calipers are secure, and no movements are bound up
believe me, from experience, you don't want a caliper to fly off into your wheel
HEY RETARD!!! its time for a new chain!!![]()
yea, get a new chain...
you're experiencing what I've heard called the "death stretch"
you can tighten it and tighten it all you want, it will keep stretching quickly until it fails.
get a new chain asap
Spes Sibi Quisque
got a nex chain, and front and rear sprockets, all set and lovin' it
did you go up a tooth or two in the back?
+1 the chain may be binding up!Originally posted by RandyO
2006 Ducati Monster S2R800
