Results 1 to 25 of 39
Paging Kurlon
    Lifer Pittenger5's Avatar
    Austin
    Paging Kurlon
    Still cant get the RMZ to run.
    On choke, runs flawlessly. Off choke, as long as I'm giving it throttle, it runs alright, lots of backfiring and the header is RED hot (have a fan blowing on it, but obv not that much air). Second I let off the throttle, backfires and dies. Ive cleaned the carb twice now, the pilot is spotless.
    What do I do.
    Zip Tie Alley #505
    Lifer lrrs313's Avatar
    Asheville, NC
    Re: Paging Kurlon
    Sounds like its running way too lean. Fresh fuel? Is the air boot attached fully? Is there a hot start on the carb that is sticking? Sounds like an air leak somewhere to me.
    -Brian
    15 S-Works Venge
    Re: Paging Kurlon
    Agreed, sounds like an air leak. I wonder if this a symptom of an FCR slide seal leak? The bike is old enough, I suspect you haven't replaced it before?
    Austin
    Re: Paging Kurlon
    Correct. I dont even know what that is.
    Oh and boots are seated probably, I checked those.
    Zip Tie Alley #505
    Re: Paging Kurlon
    Pilot jet is clear, have you blown out the pilot passages in the carb with an air compressor?
    Re: Paging Kurlon
    unless there's something going on we don't know about, your symptoms definitely point towards lean...
    I don't know how your carb works, but I'm betting on the needle NOT coming up. The clip either got unplugged, or you fucked the order up when you put everything back together. So now - the bike will start because *some* fuel comes through the pilot jet, and the choke will make it run normal because it gives more gas, and it runs super hot because you're lifting the slide (introducing more air) to make it lean, but since the needle is blocking all the fuel from coming up the main, no gas comes through.
    here are some diagnosis tips:
    1.) [air leak check] did you - at any point in time remove the carb/air boots to the cylinder? if yes - check it...if no - check it. Just make sure everything's tight
    if you truly have an air leak, it would have to be between the carb and the cylinder. Otherwise the choke wouldn't really affect the operation
    2.) [pilot/main/needle check] when you say "as long as I'm giving it throttle" - how much throttle are we talking? 1/4? 1/2? WOT?
    3.) what kind of carb do you have? how does the choke introduce gas into the carb?
    4.) [float check] with the choke on - will it run forever, or does it eventually stall? - if it eventually stalls, but will restart after a few minutes, float sticking or pin fell out. Re-check float
    5.) [gas entry check] does fuel flow freely out of the fuel line?
    6.) [fuel into carb check] with the fuel line connected to the carb and the gas on, and the bottom of the carb off, and the float needle not blocking fuel - does fuel piss out of the bottom of the carb? - if not, fuel clog
    7.) [needle check] with the bottom of the carb off, but the throttle cable connected, does rotating your throttle lift the needle? if not, take the top of the carb off, and figure out how the throttle cable lifts up the slide, and also lifts up the needle. Usually the needle is attached by some sort of clip. Make sure it's hooked up
    Actually you know what? start with step 7...
    Re: Paging Kurlon
    Wait, have you used carb cleaner on anything other than the jets when they're out of the carb? FCRs are stupid sensitive to the stuff. Don't ask why they used rubber bits that don't like carb cleaner but they did... I'm going to guess you need part #10 on this list: http://www.ronayers.com/CARBURETOR-C155955.aspx
    Walk through on replacing it: http://crfsonly.com/howto/keihin-fcr...al-crf450r.php
    While you've got the carb off, use compressed air to blow out the various passages, particularly the pilot jet circuit. Take your rubber tipped air gun and put it right to the pilot jet hole, press for a seal and then blow it clear.
    Also need to make sure there are no leaks. The normal suggestion would be to fire the bike up and spray around the intake/air boots with carb cleaner. That's a no-no with FCRs. WD40 is safer, or you can use an unlit propane torch as a gas source. With either, be aware you're pumping flamables around a HOT ENGINE! Use caution. Get the bike fired up and idling on choke. Spray WD40 at the intake boot around the lip. If using a torch, open the valve but don't light it, direct the nozzle around the intake boot. If the idle suddenly changes, you found your leak. Short tests only so you don't get built up gas vapors looking for a heat source to set them off.
    Austin
    Re: Paging Kurlon
    Jettings never been changed. No fuel blocks, no air leaks that I can find (tried the spray shit in the area test). Runs off choke with ANY throttle.
    Its got to be something that the choke "bypasses". It runs FLAWLESSLY when on choke, not a single backfire, sounds perfect, but the second I push the choke button, bam, dead. Like instantly.
    Zip Tie Alley #505
    Re: Paging Kurlon
    That points to the pilot circuit. Choke on, throttle closed, need for fuel with the main blocked by the needle is satisfied. Choke off, throttle opened, need for fuel is satisfied by the main. Throttle closed, choke off, no fuel from pilot, bike dies. If it's not the pilot jet itself it's got to be one of the air passages that feeds the pilot circuit.
    Just out of curiosity, how many turns from seated is your idle mix screw?
    Austin
    Re: Paging Kurlon
    No idea. Never touched it.
    Even when off choke with throttle I get a lot of backfiring.
    Zip Tie Alley #505
    Re: Paging Kurlon
    You're missing part of your fuel supply so that makes sense. Take a screwdriver, turn the pilot adjust screw in slowly, counting how many turns it takes until it just lightly seats. Then take the screw out. It'll have a spring on the end and an o-ring and washer, so make sure you get all the parts when you do it. With the bowl off, this is another spot I'd hit with compressed air. When you reinstall, turn it all the way in until it lightly seats, then back it off the same number of turns you counted before. Should be in the 1.5 to 3.5 turn range.
    Austin
    Re: Paging Kurlon
    Kurlon, I got a track day lined up sunday. Fix this for me.
    Zip Tie Alley #505
    Re: Paging Kurlon
    If I was closer you know I would. :/
    Austin
    Re: Paging Kurlon
    Get driving and you can come to the track day too!
    Zip Tie Alley #505
    Lifer JettaJayGLS's Avatar
    Tahoe City
    Re: Paging Kurlon
    This problem ruined racing for me last year. I got too busy, too lazy, and too frustrated and never fixed it. I no longer race. Good luck and please let me know when you find the solution. I'll be following this.
    Rookie Rada's Avatar
    Sep 2010
    Granville, NY
    Re: Paging Kurlon
    Miss having you around buddy!!
    I'll be curious to find the answer here. It was baffling last year...
    Re: Paging Kurlon
    Let me borrow your bike some time, I'll try to sort it.
    KB KB's Avatar
    Manchester NH
    Re: Paging Kurlon
    The answer is replace the seal on the carb slide. Your welcome
    LRRS/CCS EX #13
    GMD COMPUTRACK
    Austin
    Re: Paging Kurlon
    Sigh, local dealers want 25 bucks for that stupid seal, and its not in stock.
    Ronayers was 13 bucks plus 8 shipping
    Bike Bandit is 16 bucks and 7 shipping.
    Fuck all them
    Zip Tie Alley #505
    Re: Paging Kurlon
    Call Sudco, PN 021-726 and see what they can do. IIRC it's $16 MSRP?
    Austin
    Re: Paging Kurlon
    Meh, I sucked it up and went with Ron Ayers, ordered some other shit I needed anything. Just BS they do flat rate shipping for a stupid gasket.
    Zip Tie Alley #505
    Re: Paging Kurlon
    Yeah, I have to really shop around now when looking for OEM bits, between price variations and shipping variations I never know till I total it all up who I'll be buying from. I had decent luck with boats.net (don't laugh, they've had some OBSCURE Yam stuff that everyone else listed as NLA), motosport.com, servicehonda.com and rocky mountain atv.
    Re: Paging Kurlon
    Oneida Suzuki
    Honda of Hollywood ironically had the best rates a year or two back when I priced all the wear items for my 78 Honda. Shame I didn't press the go button on that.
    My local dealer now charges me MSRP + a shipping fee.. and I have to wait a week + before they get the part in and bother to call me.. why do I bother again?
    Austin
    Re: Paging Kurlon
    I dont. Ill pay a premium if they have it in stock since I can appreciate it. But they expect me to pay more than the internet shops (including 8 dollar shipping) and they have to order it to? No thanks.
    Zip Tie Alley #505
    Austin
    Re: Paging Kurlon
    Ok, that stupid gasket is supposed to come today, so I'm gonna work on the bike tonight. Any last things I should check on the carb before buttoning it all up ... again
    Zip Tie Alley #505
  1. Kurlon's GS
    Last Post: 12-04-19, 09:00 AM
  2. Replies: 1
    Last Post: 10-08-19, 02:10 PM
  3. Kurlon
    Last Post: 05-12-16, 08:28 PM
  4. Paging Kurlon - XR100R
    By loudbeard in forum Dirty Bastards
    Last Post: 07-19-15, 04:19 PM
  5. Hey Kurlon
    By Jim in forum Pit Area
    Last Post: 11-19-13, 10:16 PM
