I have a 2007 CBR 600RR. It had been parked in my garage on a rear stand for exactly 1 month. It hadn't moved due to a flat rear tire. Yesterday I figured I would get the winter storage duties out of the way since I wouldn't be riding it anymore for the year. I pulled the lower fairing in preparation for changing the oil.
The problem came up when I tried starting the bike to warm it up for the oil change. It would crank and crank but nothing. It definitely smelled like it was getting fuel though so I figured it wasn't getting spark, but I couldn't figure out what could have caused it since nothing had changed since riding it a month ago other than the tire going flat and me pulling the lower fairing 5 minutes earlier. I kept trying to crank it over with the same result. I decided to drop the bike off the rear stand and let it chill out for a few minutes. I gave it another shot and it would start to sputter a few times. Eventually I was able to get it to turn over, I had to hold the throttle around 3k for a few seconds before it eventually settled in to a rough idle that smoothed out in another 30 or so seconds.
Just curious if anyone has any theories on what caused this. I am wondering if sitting on only the rear stand, being that it puts the bike in a slight pitch caused fluids (oil or something) to settle and foul the plugs as it seemed fix itself once I dropped it off the stand and let it sit flat. I had it on the rear stand a lot last winter, but I can't remember if I just let it sit completely untouched. Either way this has never happened before. If possible I'd like to avoid this happening again in case it ends up causing more serious (expensive) issues.
I don't know if it matters but the bike has a BMC filter, Yosh Slip on and PC5.
